mountainhick
Building my first amp from scratch with a cap can and wondering about optimizing the ground scheme. This is PTP with terminal strips,
Since there are no individual grounds for the caps, there are also not nodes to group the grounds. Should I ground the PT center tap and the cap can to chassis, or run those to the ground buss? Seems the latter, but I am unsure because of the single ground for all nodes. Here is the layout sketch. The chain as shown does sequence in order for dropping B+ voltage. The cap can is n the left, the triangle the ground point. So ground that to the chassis or buss?
Oh, also how about the power tube grounds? attach to the cap can ground point?
