mew122
Not technically a guitar build, but I thought it might be of interest to some here on the forum. About a year ago I got this crazy idea in my head that I wanted to be able to produce my own lumber for building guitars. My parents owns a fair amount of land, and frequently have trees that are dying or have blown over in storms. Seemed like a waste of good wood to me, so I decided to start gathering supplies to put together a chainsaw mill. Well, I finally got to use it yesterday and here are the results.
The tree that I ended up milling was a sugarberry (aka hackberry). Three of these massive trees fell over on the old barn that my grandfather used to house chickens back in the day. This happened about four or five years ago I think.
But one of the trees was still alive and suspended off the ground, so I figured the wood was still good. So I cut out a seven foot section of the tree.
Set up my guide rails to make the first cut on the log.
Set my depth of the saw and made the first cut.
With the top off, I was able to ride the mill along the flat surface of the log for subsequent cuts.
As I was hoping for, the log had some interesting color and spalting in it.
And here it is neatly stacked.
I put some ratchet straps around it to hold it in place and hopefully prevent any warping. I also used some scrap tin from the barn to cover the top to prevent it from getting rained on.
Unfortunately, the pasture was too wet to get a truck out there to move it. So it will stay there for now. I'm hoping next week I can get out there and load it up so that I can move it to my house. Of course, this wood won't be used until it is thoroughly dried out. Probably 2 years minimum I would guess.
Although this wood will make fine electric guitar bodies I think, this was mostly a test run to get my feet wet. The real prize that I'm after is a large walnut tree in the pasture that we think is dead. Hopefully, I can get that one milled up and drying soon.
Like I said, it's not a guitar build, but maybe it's of interest to some you here. And hopefully you will see me back here in about 2 years with some build threads using this wood!
