markophonic
Are they Nitrocellulose laquer or some type of Poly?
Can't seem to find a definitive answer?
the term they use for catalyzed polyester. Rickenbacker was the first US guitar maker to cut finishing costs by dropping the lacquer based finishing systems. They piled it on thick and it looks soooo nice. It was the perfect baseline for the asian companies to copy as it was cheap to do and much faster. Players today associate the thick poly finishes with cheap guitars but Rickenbacker has been doing it right under thier noses all these years. Let the Hall disciples begin......
Rickenbacker finishes are very thin and always have been.
I just looked at a couple of my Rics again. The chip on the black 4001 bass neck shows the finish to be about the same as 6-8 sheets of copier paper -- the thickness of the finish is unmistakable. I bought this bass used, and there are a couple of pretty deep scratches that don't even make it through the finish. Scratches, not depressions -- in other words, it's the finish that is scratched away, not the wood that is pushed in. BTW, if this is a re-finish, it's a phenomenal job.
The chips on my white 330 guitar (due to an ex-roommate's cat, thank you) shows that finish to be about the same as 4-6 sheets of copier paper. So, noticeably thinner, but still pretty thick. I am the only owner of this guitar, so I know the finish is original.
I don't know what Ric historically has done, or what they "usually" do. I also don't know what constitutes "thin" or "thick," on other guitars. I know what these guitars have, and I remember the night the cat created the 330 chips -- the first thought through my head was, "I'd never have guessed this finish was so thick!" In other words, the finish never appeared thick; but it turned out that it was thick.
YMMV.
It appears that white Rickenbackers may be finished differently, without conversion varnish, to avoid yellowing. If this is true, its finish might be thicker than other Ricks. On my first 330 in the 60's, I got a tiny ding on the headstock. I can tell you that the varnish on that headstock was also very thin.
Also, concerning the black finish on your bass, I have seen plenty of Rickenbackers with chips, or with finish wear on the back. There's no way that the finish on any of them was as thick as 6 or 8 sheets of copier paper.
Read the thread from the Rickenbacker forum that I linked to in my previous post.
FWIW, my three "white" Rics are QUITE yellow now. They were quite white, when I bought them. It has been an interesting process to watch, because it wasn't at all uniform; the yellow kind of "grew." The 360-12 is a 70s model; the 330 is early 80s (before they went to black hardware); the 610 solidbody has the black hardware. My 330 has the chips.
Somewhere on the Rickenbacker forum, John Hall does say that the formula for the polyurethane CV has changed over the years, and I'd bet that the way they paint white guitars has changed, too. I'd guess it's possible that some white guitars have a CV finish, and others don't.
Concerning the bass, it seems to me that some guitars have a thicker finish on the neck (which would be subject to more wear) than on the body. Do you think that this might be true of yours?
Another thought is that solid-color (opaque) finishes are probably thicker than the fireglo (I've only owned fireglo Ricks) and mapleglo.
BTW, it's a wonderful and, to me, beautifully built guitar---the toasters have mellowed really sweetly so that it sprangs AND jazzes pretty well, AND still has some twang .
