Howdy folks,
I’m starting a new build with Walnut . I would like to finish it with Tru Oil.
Any tips, tricks or advice?
What grit sandpaper should I sand to?
Do I need to pore fill?
Thanks for any input!
Happy Holidays!
Just curious, how much does this walnut body weigh? Photos?
It’s just a body blank right now 14.5X20X1.75” weighs 12 lbs.
Pics coming as I get started on the build (not a Tele). Gonna be a Les Paul Jr Double Cut style except one neck pickup instead of bridge pickup and using a Tele bridge.
Thanks for the info!Sounds cool. And walnut can be beautiful. I worry about the weight though. In my builds I try to start with a body less than 4.5 lbs as the neck, hardware, etc adds about 3.5 lbs or so and I like my guitars at 8 lbs or less when possible.
... walnut needs pore filling...
If you want to fill the pores. You don't have to. I actually prefer the open grain look and feel.
The name of the Tru-Oil game is THIN COATS. I like to apply it with a folded up coffee filter, I recommend you do the same, it's cheap and very lint-free.
Sanding to 400 grit should be fine, walnut needs pore filling.
The first coat can be a little heavier, give it a few minutes to soak in, and then really wipe off the excess, give that at least 24 hours to dry, 2 days or more is better. The biggest mistake people make with TO is leaving heavy coats on and expecting them to dry, that's not how it works with this stuff. After that first coat is really, really dried and hard, subsequent coats should feel like you're barely applying anything at all. Two coats per day max (12 hours between). Gently wet-sand with 1200+ grit and mineral spirits every 4 coats or so just to remove airborne lint and keep things level, and apply one or two coats after your final wet-sanding, whenever that may be. The hardest part is leaving it alone for at least a week before even thinking about buffing or polishing.
Buff by hand (I can't stress that enough) with machine polish and a rag of old denim for a nice sheen, or finishing paste wax and 0000 steel wool for a matte finish.
The coats should be so thin that one of the small bottle you can get at Walmart will get you through multiple necks. I applied an absurd number of coats to a maple neck cause time wasn't a factor, and buffed it to a mirror finish like you'd expect from lacquer. The neighborhood of 10-20 coats is enough for a dull sheen or matte finish like I described, double that if you wanna see your reflection in it. Building a film takes forever with TO but it's certainly possible.
It's good stuff once you understand it, albeit only good for small projects for the hobbyist, like me!
Good luck, and share pictures as well as your experience!
I think Sconnie has excellent and nicely concentrated piece of advice here from start to finish. Reflects my experiences too exactly. I've used tru oil with swamp ash, maple and walnut and in my experience walnut started to build film with least amount of coats. I did not aim for mirror finish with my walnut bodied tele like I usually do, I actually needed to dull down the glossiness to get satin finish in the end despite having much less coats that maple top on the same guitar. Here's a link for the build thread for that one, if interested:http://www.tdpri.com/threads/red-hot-tele.613705/
Two things...
First, that red-hot tele is killer! Nice work!
Second, I'm glad someone like you with much more experience than me agrees with "my" method (derived from much research and a bit of practice) for TO.
