What glue should I use on a bone nut on a maple neck?
A couple drops of wood glue will work. Don't use super glue or anything heavy-duty, just something that will hold it in place. You don't need a permanent application in case if you ever have to remove it.
I would never use super glue....or anything else except two very small dots of white wood glue.
There is no need for a permanent, strong bond there. The nut needs to be removable with a slight tap. Ime, when a nut is super glued in, either the wood will give up before the glue bond will or the nut will break. In either case, such a strong glue bond causes more problems than it solves. Just a couple of small dabs of white wood glue is sufficient.
Sounds like we have a "failure to communicate"![]()
I don’t see any failure to communicate on my end. I was taught guitar repair by Brian Galloup in method of Dan Erlewine in the shop he established in Michigan. Bryan worked with Dan for 5 years before buying his business when Dan went to Stew Mac.
I have had nothing but trouble with nuts that have been glued in with super glue. I have seen other repairs on guitars that have been render3d unrepairable due to the use of ‘modern glues’....super glue, gorilla glue. Super glue has its uses in guitar repair. IMHO and ime, those uses do NOT entail any work that may need to be undone or redone in the future.i use super glue for nut slot fills. I will use super glue for quick finish chip repair on poly finishes.
I use it for certain fret issues.
Many people seem to think that animal-based wood glues have been made obsolete by modern glues. Nothing could be farther from the truth for wood. Animal based glues allow for disassembly and future repairs in case of a rebreak. They also are easily cleaned up and leave no trace of use if used properly.
I have seen people ruin instruments both in a functional manner and a cosmetic manner with use of improper glues.....
Two tiny drops of gel super glue. Quick and not permanent. If folks are having issues then they are using too much.
Exactly, if anything is going to take wood with it....it's wood glue .Thanks for that. Others, and myself, specified two small drops of super glue. When I have used super glue in the past, it seemed to delaminate in the glue line itself - not taking part of the substrate with it, like wood glues seem to do, in general woodworking.
IN any case, I am glad to get the benefit of your expertise - even when you are cranky![]()
