Toploader bridge for American Standard
  • Thread starter KokoTele
KokoTele
Vendor Member
albany, ny [not chicago]
A customer of mine is looking for a replacement bridge for his American Standard Tele (3 mounting screws) and wants a toploader.
I'm not aware of any, and searching hasn't turned up any. The closest thing I found was a post on the TDPRI from 2010 asking the same question, but getting no leads. Thought I'd ask here just to make sure I had all the bases covered. Anyone know of one that's available?
boris bubbanov
Tele Axpert
New Orleans, LA + in the
screamin eagle
S. CA
What about contacting a company like Armadillo and see if they can drill one of their bridges for top loading to fit an American Standard?
DanDII
Sinsinnasti
Rutters:
(link removed)
String through or top load, $130-$140 depending on saddle choice.
Mike Eskimo
Detroit
Also, don't put it on there, but an early MIM top load rattle hammer (buzz hammer ? Hmmm, I guess both...o_O) bridge will fit right on your body and use the same three bridgeplate mounting holes that are there. You could do it in far less than 5 minutes.
(image removed)
robt57
Portland, OR
I have re-drilled an AS Tele plate for 3 compensated barrel setup and used the 6 original saddle holes for the string thru holes with success years ago.
boris bubbanov
Tele Axpert
I did some work on doing this, but among other things, you've still got the yellow metal chromed bridge plate - which is not so good. I also made aluminum saddles and in retrospect that only made things worse.
KokoTele
Vendor Member
Fortunately, cooler heads have prevailed and he has decided to keep the setup he has. Part of it was that he wanted to keep the upgraded block saddles he has and likes, part of it was that he didn't want to spend real money on it.
Thanks for the replies, everyone.
reckless meanie
Bend, OR
You can’t do that. That’s what they do on the cheap ones. If you put a top loader on the guitar will sound like a Squier.;)
