Lake Placid Green
other neck woods apparently do fine without a finish rosewood, Pau Ferro, wenge, cocobolo, etc. so why does maple need to be finished and what would happen if I put an unfinished maple neck on my build?
I learned this the hard way on my recent 12-string Tele build.Even the "unfinished" wood are sealed. Most, like Rosewood, have a natural oiliness that helps repel moisture but even that dries out with age and a "conditioner" such as lemon oil has to be used to replace the natural oil.
Yes, maple has a voiceless bilabial stop and rosewood doesn't.A maple fingerboard seems like a lot of trouble - does it sound any different to rosewood?![]()
Warmoth of course tells you upfront they won't warranty their necks unless a hard finish is applied, preferable theirs, and tung oil & such doesn't count as a hard finish. But Carvin's built to order necks offer only tung oil or unfinished as options, no problem.
Since I live in the southwest I think I'll skip the finish on any future Warmoth necks and just use the oil.
I was being flippant re the sonic differences...
As mentioned above these have natural oils and are regularly treated with fretboard-specific oils as part of regular maintenance. Maple does not have the same porosity and would discolor due to the light color.
Trouble *how*? Finished necks generally take decades to "wear through" - if they ever do at all. finished maple fretboards are actually easier to clean than rosewood and other "natural" boards.
Yes, they sound different - but it's a subtle difference. Simply Google the subject.
but there a pain in the add until finished. They get grubby fast,
