So I need a real cheap bass setup for some potential jamming with some friends. I have a bass speaker in a cabinet, a Crown amp, and a Fender Deluxe Jazz bass. I assume to make this work, I need some kind of a preamp to go between the bass and the amp. This is a garage jam, so volume will be relatively low. It would be cool to have some tone controls, but at this point the cheaper the better.
I have one of those Boss EQ pedals I bought for guitar, would that work? It has 7 or 11 bands with a volume slider. I could easily make a cable that goes from 1/4" mono to barrier strip to connect them.
My guess is, I need an active device to step the signal up so the amp do it's work. Signal straight from the bass will be too low.
Could I use a single channel of a hi-fi preamp? I have some of those sitting around. At least one tube unit and one or 2 solid state units.
I'm pretty resourceful, so if you have other wild ideas about how I could pull this off cheap, let me know.
Thanks,
Onebean
Thanks,
Onebean
