Nitro Lacquer on the frets? Really Fender?
  • Thread starter the velvet catfish
PCollen
Space Coast, FL
What you should have gathered from my initial post is I saw it when received it.. I did nothing about it because I knew how to fix it.. I guess I'm dreaming of a day where someone opens their case to find bright shiny frets on a maple fingerboard instead of frets smothered and marinated in tinted Lacquer [emoji106][emoji4]
Well your dream-day has arrived, because I opened up the case of my FSR CP50's Strat (MIM) with a one-piece tinted and laquered flame maple neck and it is PERFECT...the neck and frets are flawless. Personally, I think your problem is an anomaly rather than the norm.
AndrewG
Exeter, England
It's not an item I intend to sell ever... it's just what you mentioned.. a new guitar shouldn't require a fret dressing. I played a local Blues Jam at Knuckleheads in KC with that guitar, afterwards was the Tab Benoit show and Randy McAllister opened for him. A great night that I'll remember forever. [emoji4]
What a guitar should have and what it actually has are two different things. I've spent thousands on guitars (SCGC, Martin, Gibson etc), and every single one, without exception, needed a setup in varying degrees. Expecting perfection is a futile pursuit.
Guitars are like off-the-peg suits. I have never bought a suit which didn't need a tweak here and there to get it fitting as I, not the maker, want it to fit.
the velvet catfish
Kansas
And you knowingly accepted it, played it and "defaced" the finish , and kept it for 100 days. You've made your point...it is a poor manufacturing process and now we all know it. I don't know why Fender would fret a neck before spraying the finish on it, but that appears to be the process they used in this case. And many more people will be on the lookout now for this problem, so you have done a great service to us all by bringing it to our attention. Thank you.
It was never about returning it.. it's about exposing it. Thanks [emoji4]
abrianb
Indiana
I think Ron is right, A CNC in California, Mexico or China is cheap to run. Hardware, finish details and set up is where the costs will add up.
Also consider that Fender is traditionally not a high end product. Leo made electric instruments that were functional and affordable.
the velvet catfish
Kansas
My other point is it wouldn't have cost them anything extra to spray the neck cut the slots, then fret it. That's not too much to ask is it? Lol [emoji4]
4pickupguy
Is a matter of probability…
mask the fret board and take 15 minutes to steel wool the laquer off the frets. It couldnt be easier. Keep the guitar and start putting together Warmoth guitars.
Fenders quality goes up and down from what ive seen. I personally think the mid to late 70's were an exceptionally bad period for them. Laquer on the fret is pretty ghetto for a $900 dollar guitar.
I have played only Warmoth since 85' or 86'. I have never seen a quality change in thier product. lurve thier stuff.
You can stop looking for Fender to make it right. You made choices that preclude that as an option. OOO steel wool is $3 at Home Depot. A good roll of 3M Blue Line 1" about $7. Fix it and move on.
Good luck!
ecosse
Nova Scotia, Canada
This is the neck on my classic 50's tele. As you can see there is lacquer on the frets. I can't feel or notice it at all. Normal practice on maple boards as far as I know? I've seen it on 52 RI before. Play it and it goes away.
MilwMark
near Arnold's
So maybe the summary is:
- some lacquer on the frets is normal and almost inevitable, unless you want to pay up for individual labor to remove on each guitar, in a way that the "market" generally would not bear.
- that lacquer will go away with minimal play in most cases
- @the velvet catfish - your guitar seems to have more, and more persistent, lacquer than most. That might well have been a defect. But is not representative. And if it bugs you, you should have returned it. But maybe that particular guitar is so sweet otherwise, it's worth overlooking, popping the neck off, and cleaning those frets?
How'm I doing?
ecosse
Nova Scotia, Canada
Here's another surprise for you, the lacquer is going to wear near the forearm. Part of the reason I chose this model. I'm 100% satisfied with it by the way minus the bridge pickup which I've swapped out. This is after a year of extensive playing.
the velvet catfish
Kansas
How'm I doing?
I already did... and yes it was a heavy persistent dose... I admitted I liked it too! I just don't agree with FMIC ignoring better practices and my emails. So I ranted about it trying to raise awareness.[emoji4]
the velvet catfish
Kansas
Mines already starting to do the same.. it's why I bought it... not fake wear [emoji106]
MilwMark
near Arnold's
But everyone has "defects" or "exceptions". Seems most that have lacquer on the frets have much less, and it comes right off. So yours may not be representative of anything, other than an aberration.
MickM
A steel guitar engagment.
Removing it is a one tool job. Remove the strings, lightly score the board at the base of the frets on each side with a single edge razor blade or exacto knife. The offending excess should come off without much effort. I bought an Allparts neck that had the same issue which is annoying but easily fixed.
the velvet catfish
Kansas
Regardless of its depth of defect... having been played over 60 hours, it could have been avoided by better processes. Someone deemed it fit to ship that way. This rant is my way of saying no... not cool. I have since removed the neck and this is not the typical case of Lacquer I found on my 52.. this stuff is bonding well to the frets, and I can assure you a fingernail ain't budging it lol! I dunno if the Lacquer and coloring agent they used is causing it to be a pain in the you know what but it's not gonna fall off with playing either! I tested a metal scraper and it ain't gonna flake off! This is not the typical scenario.
mitchfinck
Kitchener, Ontario
I've played it a lot! Also, these are vintage size frets on a 7.25 radius neck not the usual jumbos so marring up the fretboard is a given unless I use the steel wool technique. Imagine buying a rosewood fingerboard and having nitro covering the entire fretboard, or poly. It doesn't happen.. shouldn't be this way on a maple neck either.
Ever play a Rickenbacker? They lacquer the entire fretboard... some people hate it... I actually love it. Best playing guitar for me by far.
the velvet catfish
Kansas
I get the impression that some on here would be ok with a guitar with myriad of problems worse than mine and be happy just because it says Fender on the headstock lol!
FMIC today is resting upon the reputation of a man long gone, and two acquisitions ago. I'm no better, I bought it for its heritage and namesake. However, I can say with confidence there are better made instruments with more attention to detail at less cost available today. I remember when an American Standard was $900 new and I had no issues with those. Now FMIC is price gouging and fleecing without offering any more value to their instruments.
Now I will stop ranting and thanks for the participation and input everyone. [emoji4]
JayFreddy
Dallas TX USA
Sometimes it's an easy fix, sometimes it isn't.
I think the OP is being a little hysterical about it, but I agree with him that it would be easy to avoid.
Count me in the "hate it" camp. Love the sound, hate the feel. BTW, I had a Rick bass back in the 80's that did not have glop on the frets.
Promises, promises... LOL
I agree that Fender could and should do better. I'm not going off on a tirade against them, but I do think there's room for improvement.
Maybe I'm overly optimistic, but I think if we just stick to our guns and keep mentioning it, eventually it will be phased out.
