littlebadboy
Direct through switching. I read that by connecting the pickups directly to the output jack, the tone will be louder, stronger and more direct,offering maximum twang and spank a Tele has to offer. So, I was thinking of using this rotary switch knob to replace my tone knob because I don't use it anyway:
http://www.guitarfetish.com/PRS-Styl...h_p_18140.html
or
http://www.guitarfetish.com/5-Way-Ro...d_p_18141.html
(not sure which)
However, I would still like to have the option of the sound of my pickups passed through a resistor and cap. I thought that in replacement of an actual tone knob, I will use a 250k resistor and a 47 cap which has the same effect of setting the tone knob on high - which I usually do anyway.
So, if I may ask, is this possible and can I use the above mentioned rotary switches to make it switch back and forth from direct to output and through the resistor and cap with the 3-way switch still functioning? If yes, can anybody lead me to a diagram for this? I'm not really good in electronics and I have a cheap Hadean telecaster I'd like to experiment on.
Thanks!
or
(not sure which)
Thanks!
