Zepfan
I'm building a small combo amp for someone. It's a SS Dual IM386 Chip Bridged Amp based on my schematic that was derived from the Ruby Amp and a dual chip pedal design. Overall output is 1 to 2watts at 8ohms. will run on a 9volt battery or walwart. Using a vintage Utah 10" speaker that I got at Goodwill for 5 bucks. Whoohoo.
Made the cabinet out of Pine. 15" tall x 13" wide x 11" deep. I burned the cab with a propane torch after sanding and routing the edges with a 1/2" roundover bit. Turns out my old torch had a leak and caught on fire while I was using it. Got the fire out and went to Tractor Supply and bought a new torch to finish the job.
