jonrpick
I'm nearing the end of the initial design/layout phase of my next build. It's to be a parallel single-ended amp with a preamp loosely based on the "bass" channel of a 6G6-B, with Vibro Champ-style tremolo added in.
Should be pretty neat.
Anyway, I keep trying to get a better understanding of how much power to actually expect. This is more of an academic/curiosity thing, as I know that output in terms of "watts" doesn't necessarily correlate to "volume/loudness".
My question is really centered around parallel output tubes. We all know that push-pull is more efficient in terms of putting watts into the speaker. But I have yet to find anything definitive that will tell me what to expect in a parallel SE configuration. I *have* read things that indicate that it won't simply be double the output. For example, a 6W SE Champ won't suddenly be 12W if you slap another 6V6 in there wired parallel to the existing 6V6.
Although, one amp company built a harp amp using three 6V6's in parallel, and claims 15W.
(link removed)
So how much output will a pair of 6V6's in parallel produce?
The big "X" factor here, and what adds confusion (to me at least), is that the big difference between most 50W amps and 100W amps (at least on the schematic) is that the 100W amp appears to be a 50-watter with a 2nd pair of power tubes connected to the first pair in... parallel.
So... does running power tubes in parallel really have a significant effect on output power, or are the amp manufacturers just blowing smoke, or...??
What am I missing or not understanding here. I don't gig as a guitarist, so I'm not necessarily shooting for any particular end result. I'm just trying to understand. Every build or change I make to one of my amps is a learning exercise for me.
Thanks...
(link removed)
Thanks...
