olympic-bound
This is probably a dumb question. Can you have 50s style wiring and a 4-way switch together?
By "'50s style," I'm thinking of the Broadcaster style. Position 1 = the "tone control" knob actually just blends the bridge & neck pups, w/ the actual tone fixed as all the way up for both. Position 2 = just the neck pup, tone fixed as all the way up. Position 3 = (very) muted neck.
I wouldn't have any use for 3 in this set up. But the tone control's blend function in pos. 1 seems brilliant. If that 3rd switch position could be converted the pos. 4 option (bridge & neck in parallel), OR if that pos. 4 could just be added to this basic Broadcast style, that would be great, I think. You'd have a Tele where you can dial for just bridge, where you can blend bridge & neck, where you can switch to just neck, and where you can play bridge and neck in parallel.
Maybe too good or kooky to be true. But is such a rigging available, and fairly readily transplanatable?
By the way, "at a reeesonable volume."
Here's a stab at this wiring. The blend works in this case by putting the resistance value of the blend pot between neck "-" and ground. The blend control could be a no-load pot (see (link removed)) and w/ the blend control all the way up, position 1 would be all bridge pickup.
Thanks, wp4! This is very interesting. Do you think a maybe slightly above average tech could devise this for me, if I brought him a Broadcaster-wired Tele to work on?
Or is the Pawn Shop '72 Stratocaster's wiring (just volume and blend knob) transplantable into a Tele?
This wiring diagram is very intriguing. Would capacitor have to worked into the circuit
