mcabe
Apologies if this has been discussed here before, but I am interested in learning a little more about the pros and cons of the different master volume implementations. Adopting the Ken Fischer ruberic ((link removed)) there are 4 different types of master volume.
1. "Type 1": Post-phase inverter master volume with a dual gang pot shunting signal to ground.
2. "Type 2" or "Fischer/Larmar": Post-phase inverter master volume replacing the load resistors sitting between the phase inverter and the power tubes with a dual gang pot.
3. "Type 3" or "cross-line": Post-phase inverter master volume inserting a 1 meg pot across the grids of the power tubes, so the inverted signals cancel each other out.
4. "Type 4": pre-phase inverter master volume placing a pot before the phase inverter shunting signal to ground.
I don't think that there is a single best master volume, but each has its place depending on the circuit and the desired effect. I am interested in learning more about where these different implementations excel and where they are lacking. For example, if your goal is to generate preamp distortion at low volumes and you find phase inverter distortion to be "fizzy," you should implement a pre-phase inverter master volume. Or if your amp has negative feedback, it may not work well with a cross-line master volume.
So what are the tonal and other advantages and disadvantages of each? In particular what are the differences between the 3 post-phase inverter master volumes? Hopefully, I didn't leave out or mis-characterize anything above.
