Radspin
Well, I removed the broken original bridge pickup from my 1969 Tele (the one I had asked about in a thread about a week ago) and I can see that the wire that goes from the left solder tab (when you're looking at the top of the pickup) to the corresponding solder tab on the underside of the pickup is broken. it broke where the wire wraps around the edge of the pickup.
My question is...it looks like it would be easy to solder a jumper wire from the top to the bottom solder tab. Would this get the pickup to work again? I would think so...electrical continuity would be restored...but is there some reason why it wouldn't, and that the actual coil wire itself would have to be spliced back together? COULD that wire even be spliced or soldered back together? I know I can't handle soldering that fine a wire.
