grolan1
I have an Eric Clapton Tremolux - it came loaded with a Celestion Heritage G12-65 speaker. Being an expensive amp I assumed it would be a great speaker. I built a 1x12 pine cabinet and loaded it with a WGS ET65 speaker which sounds great. Ran it with an Orange TT for awhile. For grins I plugged the WGS ET65 cabinet into the EC Tremolux. I was amazed at how much better the WGS speaker sounded than the Celestion G12-65! The G12-65 seemed to breakup at medium to high volumes, but the ET65 was clean and wonderful. Yes the amp itself was breaking up, but the speaker was as well. As you know one of the problems with lower wattage amps is the clean headroom, this speaker not only goes a long way to help that out, but also sounds better. Still amazed how much better the WGS speaker sounds then the Celestion. I personally don't dislike speaker distortion/breakup, but when you have an amp that is very prone to breaking up, I want my speaker normally to not do the same thing. Also the WGS was louder which is surprising as they both rated about the same spl.
Since the Tremolux is an the border of being under powered for gigs, I ordered the newer version of the speaker from WGS, ET90 which is even higher SPL rated (giving it more seemed volume). I installed it and it sounds not only as good if not better than the ET65, it is slightly louder. This will bring the Tremolux one step closer to be a real gigging amp for sure. I may not need the second 12" speaker cab after all.
I can't convey how happy I am with all of my WGS speakers... not only do they do a fantastic job, they cost must less than there competitors and ship super fast from here in the good ole USA!
On a side note, when putting in the speaker in the Tremolux I was very happy to notice the transformers are Mercury Magnetic's, something you would have thought Fender would be advertising!
