esteban_miguel
I'm looking into getting a Princeton Reverb and I'm debating between a vintage black face or a vintage silver face. I would like to know about the pros and cons of each amp. Thanks
There's usually a substantial difference in price between the two. The black faceplate is going to cost some extra coin.
Weren't the later BF Princetons built the same as the earliest SF Princetons ?
Blackface and possibly early silverface has a screwed in baffle that makes it easy to switch to a 12" speaker and back if you want it original. I gig with a 74 SFPR with a 12" Cannabis Rex speaker, I can't imagine wanting a 10" in it again.
The schematic for the Princeton had very few changes except for the rectifier across it's entire life (except for early versions prior to the blackface era). There really is almost no BF/SF differences except for cosmetics. Not so for other Fender amps.
Blackface and possibly early silverface has a screwed in baffle that makes it easy to switch to a 12" speaker and back if you want it original. I gig with a 74 SFPR with a speaker, I can't imagine wanting a 10" in it again.
There will be a difference in signal caps. I had a BF 64 Princeton Amp (non-reverb) that has the blue molded signal caps and there was a difference between its sound and the SF 77 Princeton Reverb with blue and brown blobs. The BF sounded heavenly. The SF was less sweet, but still ok, just not the same. Probably wouldn't be noticeable in a band, but I heard a difference.
Actually, there is a difference in the sound of a Princeton (non-Reverb) and a Princeton Reverb no matter if it's Blackface or Silverface or what color the signal caps are.
The reverb on the PR uses one half of a gain stage on one of the pre-amp tubes. Obviously, without a Reverb the Princeton doesn't. So, the Princeton has more gain and different touch dynamics.
So, I don't at all doubt that the non-reverb Blackface Princeton sounded different than the Silverface Princeton Reverb. They always have. Now, if you're one of those folks that can hear a difference in signal caps then, maybe you heard that difference, too. But I'm not one of those people.
Go for the SF. Same circuit. Save several hundred. That and the champ had almost no changes.
