I got a Jazz Chorus 77, but the reverb tank died. After doing my research I decided to stick with the short tank, upgraded to 3 springs, so I got a new 8AB2D1A replacement tank. I would have got a MOD brand tank because I've heard good things, but couldn't find the proper model anywhere, so I went with Accutronics. It's supposed to be a direct replacement, mounting open side up on the underside of the chassis.
Anyway, I have some issues installing it. The original tank (marked Hokusei) was attached with just two small screws with plastic sleeves (I assume to dampen vibration), one on each end (in the middle of the short sides of the rectangular tank). The Accutronics tank doesn't have mounting holes on the ends, just the corners. It doesn't even have a rim on the short ends, so I can't just drill matching holes in the tank itself.
I'll have to use a screw on each corner, but I'm not sure if there is room. Has anyone done this replacement themselves, or have any advice for mounting it? Can I drill new holes up into the chassis? Also, the Accutronics didn't come with mounting hardware, and the holes are too large for the old screws anyway (plus I'll need 4 instead of 2)- any tips on proper screws and anti-vibration sleeves or grommets?
I can take some photos if it would help.
Thanks!
Thanks!
