ce24
Are these worth building...I would be using it with my Vibrochamp and 5E3. klooks like I could build one for like 25 buks.
Thanks in advance
Thanks in advance
On a side note, I like to play my silverface Twin on 7, so to not level the house, I use a Weber Mass 200 attenuator, which sounds great.
DRRI on 5 with a Hot Plate is my thing.![]()
I'm not an electronics expert, but I've seen this question come up before.. about using an L-pad to attenuate an entire amp... and the answers were along the lines of "that's not what they're for... could easily damage your amp."
I think the reason being that L-pads are more or less designed to be used with higher frequencies, like tweeters, which draw little current. A full-range guitar signal will need a resistive load when it is being attenuated (like a Weber Mass), or you risk damage to the amp.
Again... I'm no electronics expert, so someone can correct me if necessary.
Just wondering, why would you want to attenuate a Champ?
I got one for my champ from parts express for like 6 bucks (just the attenuator, no box or anything) still not sure how to hook it up
Would making a box of it (I assume using guitar cable connectors for in & out) sound the same as hooking it directly between speaker & amp?
