Tutorial - Print 100% Scale Mock-Ups on a Home Printer.
  • Thread starter Guitarnut
Guitarnut
USA
EDIT: I should have pointed out that there are many ways to do this. Some considerably easier and more efficient. I have access to many of these including programs like Illustrator and Photoshop as well as large format printers up to 18" x 12". This is a basic tutorial that folks can accomplish with only Acrobat Reader and a printer.
Seeing the continued interest in the the Printable PDF thread, I thought I would put together a tutorial on using a home printer, standard 8.5" x 11" paper and Acrobat Reader to print and mock up full scale prints. Olav touched on the subject in the thread but I thought a step-by-step might be useful.
Is it easier than running down to Kinkos? Nope. But it's good info to have when you want to save some cash or experiment with your own designs. Plus, it's easy to do and you can make as many as you need to get you through a build.
Acrobat Reader (AR) has a feature that lets you print the current view port. Knowing how to navigate and size the PDF to take advantage of this can be a bit tricky. First load up your pdf in AR. Make sure to maximize the app so it fills your entire screen. This isn't necessary but you'll get more image per page this way. If you forget to maximize, just don't change the current view size until you've finished.
Here's our subject for the tutorial...an SG plan that has several different scales within it. We're going to focus on the front of the guitar to make a body template.
An important bit of info is that regardless of your monitor or graphic card resolution settings, screen resolution is always 72dpi. What this means is that if you match the drawing on screen with a physical ruler or caliper, the drawing will print that size.
Set a zoom level, check it with a ruler flat against the screen and adjust zoom level until you have a match. My screen res is 1024 x 768 and I've sized AR to 58.5% zoom. This makes the width of the fretboard 2.25" at the 22nd fret on screen. If your screen resolution were higher, you would need a greater zoom level to make it appear 2.25" on screen. 1280 x 960 would require 76% zoom. AR will let you type in fractional zoom values to really dial it in.
Here's my printout.
Back in our pdf, set the upper bout of the body in the current view. Then select the print command which launches the printer dialog. To get the view translated to real world prints, use the following settings in the AR print dialog. Print Range should be set to Current View and Scaling should be set to None. You may have to cancel and slide the view port around to get the printable area correct. When you have it, press OK to print.
Use the scroll bars at the bottom and right of the AR window to set the view port to the next part of the body. I just used the right hand bar to slide down.
Repeat this for however many views it takes to get the whole body. Note that the bridge PU is visible in all views. Always make sure you have a good amount of overlap from one view to the next. You'll need this overlap when trimming out the mock-up.
Next, we'll trim them out and make our mock-up.
Guitarnut
USA
Here are our printouts. Obviously, there is a lot of overlap but this is okay. We need to trim all of the adjoining edges. You don't actually have to trim all of them but it's good practice and simplifies assembly. And most printers don't print to the edge of the paper so some trimming would be needed anyway.
First,we check our scale one more time.
I like to trim thru a complex area...like for the lower body sections, along the A string. This leaves a complex edge with lots of visual points to line up. I trimmed the upper body sections along the B string. This gives you 2 clean edges with lots of detail and leaves plenty of overlap.
After you have them trimmed, start lining them up and taping them in place. Take your time and make sure you're lined up at several points across each printout.
There you have it! One full size SG printout.
Mark
davmac
Wirral, UK
+1 for a sticky. Great write up. I'm sure you probably already do this but it is worth pointing out that when you're checking the scale you should do it horizontally and vertically because some printers will slightly compress in one direction.
I use a very similar approach, but with Inkscape a free vector drawing program. Inkscape will open a PDF file, and allows you to scale it to a specific size (and you can use mm or inches). The big benefit I find is that it allows you to overlay the plan with a pattern of diagonal lines, which really helps with alignment when sticking the sheets together.
Guitarnut
USA
Yeah, I usually use Illustrator but this file is password protected so i couldn't open it in anything other than AR. Seemed like a good opportunity to do a very basic tut...most folks have AR and a printer.
Jack Wells
Albuquerque, USA
There's a similar way to do it in Adobe Reader. It doesn't depend on your screen resolution or zoom level. You use the snapshot tool to crop four overlapping rectangles of the guitar body. Set page scaling to None and each quadrant will print actual size.
Olav
HLMRmeer
Never realised this was a democracy...
but I'll vote for 'Sticky' too.
Guitarnut
USA
If you mean each quad would print at 100%, with this PDF that would give you 4 quads of a scale drawing...not actual size.
Plus this is a locked document that you can't even draw a selection in...that's what lead me down the path I took. Probably not the best approach or example for a tutorial.
Mark
majorbugout
NY
Yet again the answer too something I was wondering about appears in detail on this forum!
Guitarnut
USA
How-To For Illustrator
I thought I would add the steps for using Illustrator. I'm guessing fewer folks have it but if you know someone who does, maybe you can ask for their help and impress them by showing them your new Illustrator chops. :cool:
This file is a DWG that isn't to scale.
First, we want to group the objects for easier selection. Use the select tool to draw out a marquee around the body. Then go Object > Group.
Then do the same for the headstock or any other groups you want to create. This is important because we're going to move both groups to the same art board and selection would be a major nightmare without grouping.
We're moving them all to the same art board so they will be inside the outer selection as we scale them...all will scale equally.
Now select the entire set of objects and click the Transform link top right of the interface. We can see that the current selection is only 4.729" wide.
Making sure the Width and Height sizes are linked...paperclip beside them should have fly outs showing they're linked. Click in the Width box and type in the proper size...13" in this case and then click in the Height box...you'll see the drawing update to the proper size.
If we try to print at this size, Illustrator will ignore the objects outside of the page...or art board. We need to adjust the art board's size. Select the Art Board tool (Shift +O) and drag out the corners to make it large enough to fit the objects. Hit Escape or another tool to return to the interface.
Once back in the interface, click on any part of the headstock or other groups and move them out of the art board.
Now select Print and in the print dialog make the following selections.
Paper size for your printer...mine is 8.5"x11". Chose Tile and then set the overlap to 1"...this is the area you'll use to trim the unprintable edge of the page like explained above. You should see all 4 arears defined in the print preview as well as the overlap areas. Click Done to print.
Resize the art board as needed for other groups and print them...Tiling and Overlap may not be needed. Then pick up your prints off the printer and trim them out and tape them up as explained above.
bendeane
Kansas City
Just FYI, look for local mom and pop sign shops the print on poster paper or even light tack adhesive backed vinyl. Many times they are cheaper than somebody like the ups store or kinkos. They cater to business folk who want all their printing services in one tidy place and charge way more than market value for large format prints.
SamClemons
Jasper, TN
There are a lot of large format print shops that can do all kinds of prints on all kinds of material. I am blessed. I run a surveying office out of my house and have a full size printer that will print out up to 36"x60" sheets plus Autocad etc.
