SF Princeton Reverb help - loud pop then....
  • Thread starter BootRoots
BootRoots
Cincinnati
While playing my drip edge PR yesterday, there was a fairly loud popping sound (almost like when you when you plug your guitar in to a live amp.) and then the vibratio basically pooped out. I first thought there was a short in the cord. The intensity knob seemed to almost turn into a gain knob with more grit and crackling as I turned it up. not good:(
The trem channel has been giving out a modest hum for a short while and I have been meaning to get some new tubes, but I'm curious if there is anything else I should be concerned with regarding this problem.
Thoughts?
trev333
Coolum Beach,Australia
mmm!?.. sounds similar to a tube amp of mine...
working fine one day on for 6 hours quiet as a mouse,,,except for the tele going into it,
then next day.. turned it on... then after 30 secs or so a loud pop and a bit of a crackle stayed..
I reseated all the tubes to make sure it wasn't pins.. I didn't put a meter over it... tried it a few more times... mhea... one day...
just put it aside and plugged my super 210 in as usual...
man this thing's a truck.. on all day ,every day, morning until late night.. just sitting there ready for me to twang on,
it's got no hiss with 2 guitars and a 2x12 plugged into it mostly... hardly notice it's on except for the pilot...
Caps on the bias circuit eh?.. I'll have to check them... it's got old type valves with the cathode leads coming off the tops... 60's vintage Goldentone Reverbmaster,
Surf city!...
kosmonautmayhem
Chicago
+1 on checking all tubes one by one. And a cap job if it's never been. Especially the electrolytics!
I have one power tube in my SFPR that's starting to go. It crackles and pops on startup and then after about 15 min. its okay. I only its this power tube, since I've subbed known good tubes in each one til I found the culprit.
BTW, Trem is being modulated by the power tubes and half of V4 12AX7.
Cheers,
kM
BootRoots
Cincinnati
The popping sound could have been the bias cap going south. Remember, the PR has the bias wiggle vibrato.
pretty ignorant as to what exactly that is, and I'm not sure if this will do any good, but is there anything in the following pics that looks suspect. It doesn't look like anything has been done to it.
image removed
image removed
image removed
image removed
image removed
max_twang
New York
Your amp has had a bunch of caps (I count 6) changed. Don't worry, that's a good thing. The exception appears to be the cap can, which should probably be replaced, even if it's not the cause of your current problem.
From your comment above, I'd recommend taking it to a tech, unless you want to invest a lot of time reading and a little $ in equipment, and then start replacing various components.
BootRoots
Cincinnati
thanks for the info. yeah, I wouldn't trust myself to work on this thing, so a tech would be the way for me.
max_twang
New York
You're welcome :)
If you're inclined, there's a lot of info around here about how to work on and troubleshoot tube amps. I've learned a ton from reading the comments of other posters. Read first, learn the basic safety rules and start small. It's really a lot of fun once you start to know what you're doing!
fezz parka
Del Floria's Tailor Shop
Bias electrolytic is in the upper left hand corner:
BobbyZ
Snellman MN
Damn I miss Fezz! Bought two sets of his pickups, Oildales. (think that's what he called um) Best thing I ever did to my Teles!
