Ok... didnt know blues driver was copied too... Which do you think is better version of those (the boss VS digitech) pedals? In case you have played them.
I take them on an individual basis. I don't really like a stock BD-2, so the SB is out for me personally. But others like it stock. The SB sounds a little different (as it should), because of the adjustable bass. It's knob would have to be set in an unorthodox position to match a BD-2.
I think a stock Hot Head is a little better than a stock DS-1. That said, with just a few judicious mods, a DS-1 will rival many other distortion pedals.
I can see how folks like BM with the bass knob, as it can really be a problem with a TS. The biggest issue for many is that the buffered bypass in the BM can be noticeable. IDK why they didn't use the fantastic bypass from the BD-2 (like in the SB), but there you are.
All of the Digitech pedals use surface mount technology (same components/construction method as in your computer, cell phone, etc.), so it makes them difficult (impossible for folks without great eyesight and a very steady hand) to modify. And most Boss pedals can sound significantly better I
MO when properly modified.
How dose the EQ control work on those pedals BTW, is it more like a EQ gain boost on certain frequencies or a filter being rolled backwards?
They are all
active gain boosts on the Digitech line - it's the exact
same type of circuit as you will find in a graphic EQ. That is, it boosts a specific frequency with a gain greater than one. In the case of active EQ boosts in pedals, it's not uncommon for them to be designed with a
lower Q than an EQ pedal.
Q stands for how "focused" the EQ boost sounds, and it can make a frequency stick out like a sore thumb. A lower Q will "spread" the boost over a half an octave, or even more.
...You could actually modify the post level boost in a BD-2 to sound like a notched wah, or a subwoofer low frequency boost, as the technology is borrowed from general audio usage.
