Uncle Daddy
This just came up on a forum. Is there any value in using a bypass cap on the bias adjustment pot?
Thx.
Thx.
Thx.
I think there would be a naturally formed signal V AC null point at the junction of the grid leaks, because their values are the same and the V AC at either end is equal but opposite.it also decouples the grid leaks from one another (I assume this means more gain is had from the preceding PI).
I'm not exactly sure what's meant by bias sag?It would be interesting to determine if this extra cap had any effect on the perceived “sag” characteristics of the amp under heavy duty. I would hypothesize that the extra cap would reduce bias sag
Hence connecting a decoupling cap there kinda seals the deal but doesn't actually have any material effect on the AC signal analysis.
So as I see it, connecting a decoupling cap there can't reduce the loading on the preceding stage (phase splitter), so no increase in gain, sorry![]()
My understanding is that grid current clipping at or near typical overdrive signal level causes signal rectification and pushes the grid more negative.
I'm a bit stuck trying to work out a mechanism by which that might be the case. Could you explain your thinking?Also any hum induced by uneven power tube matching should be squashed right?
Ok, compared to HT sag, any sag of the bias supply will tend to be a related but secondary, lesser effect. ie bias sag will invariably tend to be a lower % reduction than HT sag, especially so at the screen grid (anode current being determined by the relationship between control and screen grid voltages). So even without grid current clipping, the combined result of sag (HT and bias) will generally tend to be that the net instantaneous bias level will become a bit colder.I’m talking about the natural sag of the bias supply due to loading of the PT as the amp gets into Class AB up to maximum clean power. Is that not a thing?
No, with signal, with most AB loadlines, anode dissipation will almost invariably tend to increase above its idle level. Aiken demonstrates how this takes place hereI thought that was one of the reasons we don’t bias up to 100% on fixed bias.
Indeed, adding a 2nd RC filter stage, even if the values seem fairly low, generally makes for a much more effective result than eg just making the reservoir cap much larger.Without a cap off the wiper and a 470 ohm resistor with a 100uF cap you get a sawtooth wave with about 550mV swing peak to peak.
This drops to less than 10mV when a 22uF cap is added to the wiper.
This makes an audible difference.
It's kinda stating the obvious, but there's little benefit to be gained from improving something beyond 'good enough'1-cap solution is almost certainly adequate
The traces look the same?According to LTspice
The green traces are without any capacitor (actually just a really small capacitance for simulation purposes), the blue traces are with the capacitor in circuit.The traces look the same?
You can model this in PSUD.
According to LTspice...
I think so.Can I assume it does a similar job in smoothing the bias supply?
I think there will be.Is there an advantage in connecting it from the bias feed to ground, as opposed to bridgeing the tail resistor on the bias pot (original post)?
The simulation outputs in post #12 answer this question.Is there an advantage in connecting it from the bias feed to ground, as opposed to bridgeing the tail resistor on the bias pot (original post)?
