If You Have An "Always On" Pedal You Need A New Amplifier
  • Thread starter omahaaudio
Well?
  • Yes, Always On Pedals Are A Crutch!
    Votes: 20 36.4%
  • No, I Have Too Much Money Invested In Pedals!
    Votes: 11 20.0%
  • I Love My Pedals And Would Cry If I Had To Give One Up!
    Votes: 14 25.5%
  • Maybe It's Really My Choice Of Guitar...
    Votes: 23 41.8%
  • Total voters
    55
Status
Not open for further replies.
Brent Hutto
South Carolina
Three little words...
Clean
Pedal
Platform
For me a simple, three-knob $90 Boss OD-3 into a clean Katana amp sounds so good I can't imagine going and spending hundreds of dollars trying to find an amp that sounds the same without the OD-3. Not to mention the knobs on the OD-3 are right there by me, when the amp is clear across the room.
Couple hundred bucks for a solid state/digital amp and less than a hunnert for my always-on pedal. Pleasing tone doesn't have to be expensive.
Brent Hutto
South Carolina
I
I use my Joyo American Sound to prevent me from needing a $1500-$2000 amp. I need a $35 pedal into a $150 amp a lot more than I need a Tweed Deluxe.
I have played (in a store) through a nearly $1,000 Tonemaster Deluxe Reverb and an over $1,000 tube Deluxe Reverb. The sound I'm looking for from my guitar does not exist in either of those amps.
I've also plugged into a Marshall style "EVH" amp and a huge 2x12 cabinet one time. There's a lot of sounds I could like in there but the cost was even more than a tube Deluxe and, more importantly, at the volumes I turn down to in my living room it didn't like much of anything.
Highway 49
UK
I’ve ticked all four. Sometimes I love the idea of the pedal (not necessary a drive pedal) that somehow brings the guitar and amp together, and sometimes I love the idea of just plugging in…🙂
Jimclarke100
Horsham, UK
When playing into an amp, it’s into a 5e3 champ clone and then I nearly always have a reverb pedal on. It really only comes off if I’m playing at full whack where the distortion trumps the reverb.
No I don‘t need a new amp - the champ sounds wonderful.
1293
What is a 5e3 champ? I have a 5e3 Deluxe.
bottlenecker
Wisconsin
I mean whatever works. I'm not going to tell anyone else how to cook their own recipe, but if I found myself needing a shabby little 9v transistor circuit to do something other than a special effect, I'd probably consider it a bandaid on a problem with my guitar or amp.
Then again I like some pretty trashy lo fi old stuff.
mexicanyella
Troy, MO
I’m generally happier playing through a compressor than not, so if I am playing through an uncompressed-sounding amp, like my Peavey Special 150’s clean channel, I like to have an always-on compressor in the signal path.
More recently I have been playing through modelers into a power amp and cab, and I always have some amount of compression in the virtual signal path.
I don’t see it as a crutch; if I had an amp with onboard compression that I liked I’d be happy just using that, but I don’t, and I do have a compressor pedal I like the sound of, so...
schmee
northwest
You've seen the subject header, what do you think?
BS.
If it was installed inside the amp chassis as part of the pre amp section would it be OK then?
Because different guitar amps may have anywhere from 1-4 tubes and related electronic things in the preamp. So which amp is "pure" the 50's tweed with one pre tube or the Super Reverb??
Pine Pitch
Rural Maine
Yes it’s a crutch. But I need to have some crunch on tap. If I turn my Princeton up to the point where I’m getting some crunch, the people around here are whinging.
Status
