tkmclaughlin
First I apologize that this is not guitar-related. But the folks on this forum are smart and tool savvy and I don’t know who/where else I could ask this question. I am hoping someone might take pity and respond with some wisdom.
I’ve got a some office chair wheels that are connected to the mounting post with a central Allen bolt. Over time, that bolt loosens. When loose, the wheel doesn’t operate properly (it gets stuck in the wrong direction and won’t swivel to the right position and, as a result, the chair won’t roll properly across the floor. It gets stuck.
The solution is easy - just tighten the Allen bolt until it is REALLY tight and won’t loosen.
The problem is that the wheel gets in the way of the Allen key and you can only get it jammed in on an angle. See photo. You cannot get any torque to really tighten it. So it just loosens again. And again. And again. And again. And again. I’ve tried squeezing crazy glue onto the threads. Loctite. Nothing works. It just loosens after 5-10 days.
Do any of the engineering-minded folks here have any ideas or suggestions (other than just buying a new set of wheels). Could I jus chuck the Allen key into a vice and start hammering the bastard until the 90 degree angle is more like 45????
