Bourbon Burst
On both channels (Normal and Vibrato).I did not know this! I'll try that later for sure. This is the second input on the channel with reverb and vibrato?
Have you tried the second input which has a pad for humbuckers? I have a 1975 silverface twin reverb and using my 50s Les Paul works well on that input and with the bright switch.
THIS^^^^.Perhaps you're just not a humbucker guy.
Nothing wrong with that at all.
...for those reasons, the pick-up change sounds like possibly the right solution, and I'll try it tonight - this definitely does feel like something that's more of a source issue than amp issue....
Unless volume is on '2' having bass at '5' is almost certainly too much with Gibson-type humbuckers.
Not necessarily, if one plays through a set of Filtertrons or Minis.Humbuckers and "great clean tone" is an oxymoron
On the FMV tone stack you have to be careful. The treble is also a master eq control. If you have it past midday it can start to effectively increase the mid and bass settings and those controls lose effect.
The 'rule' with setting Blackface amps is once past low volumes, you typically need to drop treble, mids and bass to 6 or less.. To some degree this is interactive with your guitars volume and tone controls. If you keep these dimed the amp settings become more important.
You're also battling the Fender AB763 tone stack, which was aiming for massive sparkling cleans with long spring reverb. It's inherently scooped in the midrange. Reverb settings past 3 will tend to make any distortion sound messy.
If you boost bass past around 3 and mids past 5, you will not only get blocking-type distortion, but it will be reverberated which will indeed make it sound both harsh and muddy at once.
If you're looking for a bluesy edge of breakup tone, the TR is maybe not your amp. It's more a BB King type device.
Egs on 5 - nup. That's your issue. Too much. The AB763 was developed when the highest gain/, output pickups Fender made were the Tele bridge and Jazznaster soapbar. Even with them you can't run bass past 3 with treble on 6 and mids 5-6 with volume past 2.This is super interesting, thanks! I didn't know the treble was a master eq, and will keep that in mind.
I have always had all the eqs on 5 since I bought the amp, which works great for my Fenders, and like I said, turning the bass down made the amp sound really boxy, but I'll mess some more with it. (I do tend to have the volume at 2-3 except when I'm playing with someone).
True, but double-coil humbucking pickups nevertheless. Not that such nitty-gritty matters a whole lot, but still.but not the "humbuckers" 99% of guitarist think
