JustABluesGuy
I just bought a used, 2006 Champion 600 Reissue. It appears to be completely stock and barely even used. It’s in great shape, and even has the original Chinese tubes.
I’m looking for tube and speaker swap suggestions for it. I have a couple of 1960s Oxford alnico speakers, but they are more like 7 or 8” rather than the stock 6.5” speaker, and would probably require modifying the baffle. I would probably just make a new baffle with an oxblood grill cloth and put the original speaker and baffle away for safekeeping, but things tend to get lost around here, so…
IIRC I the Oxford is 8Ohms (I need to double check). I’m concerned about matching the impedance of the original. Since there IS a standard speaker jack, I’m likely to leave the original speaker and match it with a 4 Ohm cab, probably a 2x10 with ‘74 CTS Alnicos (pulled from a SR).
I would like to hear some more affordable options for replacement tubes. I only spent $65 on the amp itself, and don’t need NOS tubes. Modern production is fine.
If anyone has any tips or tricks for using this amp, I would love to hear them. I’m glad the amp seems unmolested, and I’m not too interested in any major, or irreversible mods. I am not qualified to drain caps, even with one hand behind my back.
I’m interested in any easy to do, and easily reversible mods that might make it a bit more tweedy, or less boxy.
I’m also interested in finding others who have, and use this amp. I would like to hear your experiences with it. What you like, or don’t like about it. How you use it, etc..
Thanks in advance!
Thanks in advance!
