Recommend an inexpensive but reliable volume pedal?
  • Thread starter RoscoeElegante
RoscoeElegante
TooFarFromCanada
I really like adjusting reverb, delay, etc., as I go, especially since I'm our group's sole guitar player. I often use two amps, and like to vary the wet and dry's relative contributions.
Thanks for your advice.
arlum
O'Fallon, MO
Are we talking about a volume pedal or an expression pedal? One adjusts volume. The other adjust effect pedal parameters like delay time, etc.
BB
Great Pacific NW
I've gigged with an Ibanez VL10 for the last 35=40 years and it's still going strong with never, ever a problem. It's stereo and an be used as a regular old volume pedal, or to pan between two amps.
It has a great feel and throw.
schmee
northwest
I like my Roland (?) $20 simple keyboard old school Volume Pedal as well as any of the fancier optical etc ones I've tried. It's just a volume pot attached to a gear. No electronics other than that. Similar to this but not even this fancy!
TelePickler
Northeast
For a volume pedal, the Ernie Ball VPJR has served me well for years. But it sounds like you want an expression pedal for adjusting effect params.
RoscoeElegante
TooFarFromCanada
Hmmmm. I like the idea of the pan, as I often use two amps, in the wet and dry mode.....
RoscoeElegante
TooFarFromCanada
I'll have to look into that. My goal is pretty simple. (It would have to be, given my all-thumbs electronics skills.) Increasing a reverb/delay pedal's input into a given amp. I realized I do have a volume pedal on hand. So I'll fiddle around with placement, etc., to try to make this work. If I can't, I'll look into the Ibanez VL10/panning pedal approach that BB suggested above, and the expression pedal approach. Our venue is a fairly reverby place to begin with, so I need just a subtle variability. (It's too bad you can't clip a little pedal control knob onto your guitar itself. I'd rather use fingers than feet....)
Thanks for your replies, everyone.
  • Like
Reactions: BB
