Installing a kill switch
  • Thread starter RustyMcdangles
RustyMcdangles
Canada
UserNotAvailable
You may want a high kohm (10kohm?) fixed resistor across the switch to lessen the snap on/off. Look up the stutter switch mods.
HEY, thanks BIGdog for mentioning the *resistor Tip!
Peegoo
Beast of Bourbon
What do i do with regards to the rest of the wiring on that switch?
There is no other wiring.
The switch you linked to has two terminals. Polarity does not matter.
One terminal on the new switch gets a wire that runs to the line supplying the signal to the output jack. The other terminal on the switch gets a wire that runs to ground. You can add a resistor to either wire, in series, like @jvin248 describes above.
Everything else stays the same as on your wiring diagram.
IMPORTANT: if you want to do a fast stutter, you need a "momentary ON" switch. This is a switch that does not click on with one push and click off with another push. It makes contact only when you're leaning on the button. The button you linked to is an ON/OFF switch, and a fast stutter is not possible with that.
radtz
Wisconsin, USA
FWIT, I treated myself to a large socking stuffer presnt of an Epi SG Special. It has a "Kill Pot" volume knob. Its a spring loaded pot that acts as a momentary kill switch when you push it down. If you use one of these, you wouldn't have to drill another hole.
Amazon product ASIN B002XUCZI0
RustyMcdangles
Canada
Peegoo
Beast of Bourbon
@RustyMcdangles This is how it gets wired with the PP switch removed.
ALSO, note that the diagram below shows the kill switch connected to the jack; I did it this way for clarity based on the diagram you provided. You can make that connection to the other end of the jack wire where it connects to the vol pot's tab #2 and it will work fine.
RustyMcdangles
Canada
Okay gotcha that makes sense. Thank you
RustyMcdangles
Canada
Is this correct
