??Built about as good as a Walmart flip flop. Hope she holds up.
Have you been inside one?
I've never used the FA you mentioned but my church rig is easier and cheaper. Plus I really like how it sounds.How many of you feel your AC10 with pedals is superior to something like a Fractal Audio Multi FX/ Amp modeler using monitors or FRFR/ PA systems? What is the real advantage to using the traditional tube amp and pedals?
Do any of you use both systems? If so I'd love to hear your comments too!
Vox AC10 does have a master volume. So you can dial up gain at low volume. Perfect for home use.Guys, what about home using? Is it loud? As I see there is no master volume (for example like on Fender BJ). Going to buy, but still not sure about volume control for home.
I have not tried it, but the AC10 and its purpose/design has about as much in common with a PA system as your refrigerator does. This is a 10 watt guitar amplifier designed to break up at lower volumes.Anyone tried using an AC10 as a PA system? Which connectors to turn it into a PA did you find best? I have a nice mic stand and SM58 but at gigs they expect me to bring my own MIC to speak to the crowd and I don't always have access to FOH's systems, mics, PA's etc.
I was pretty shocked to see the inside of one of these things. I mean, I've seen the insides of inexpensively built amps with thin PCBs, ribbon connectors, and what not but Vox was not to be outdone!Have you been inside one?
Blow one up and you'll have to buy another.
Holy smokes. I cannot imagine running the treble at 3 o'clock on one of these amps. The treble would be unbearable. It must be that your attenuator is really rolling off the high end and you're compensating at the amp.Amp settings are
-Gain 1 o’clock
-Bass 10 o’clock
-Treble 3 o’clock
-Reverb just a smidgen on
-Amp volume 1 o’clock.
This is pretty much my always-on base tone— grit and breakup are crisp and very guitar-knob & attack sensitive, for all 4 guitars I play, tele, les paul, jazzmaster with P90s, and Squier JM baritone.
The output end might make a difference mnm too—amp runs through a Jet City passive attenuator (to scale down for bedroom volume, + match impedance) to an Avatar closed back with 2-10 Celestion golds.
