Ok, here's one that I need an explanation about.....for whatever reason, I've always turned the volume on my amps up quite high, 7 or 8, and adjusted the level on my guitar to suit the setting, regardless if gigging or at home. Brought home a CS Tele last week with a HB in the neck and I was having a hard time getting rid of the "woofiness" in the neck position, especially the low E and A strings. Tried all the usual things, like lowering the pickup on the bass side and raising the pole pieces on the E and A, yadda, yadda, which helped a bit. Fooled around with the eq settings on my amp, again, with not much help. Out of frustration, I turned the volume on the amp down to 2.5-3 and voila, the guitar sounded crisp and clear on the neck position, when I upped the guitar volume. Of course, when I switched to the bridge, it was way too bright, but that's what a tone control is for, right???
So, my question is, why? Is this something I have been missing all along? I did notice with my regular single-coil neck position guitars, they all sounded fuller and bigger.
Thanks for any insight.
