ElGuapoTaco
I have an original 1966 Princeton and want to run medium high gain distortion with my DIY overdrive I built. I also have a Klon clone, but I’d like to run something a bit hotter for the base distortion. Any thoughts?
Thank you, I have never heard of each of these pedals. The one I have right now for higher gain is a cheap amazon thing for metal and it’s just too much to try and dial it in at super low drive when stacking with a KlonWhat kind of medium high gain are you looking for and what's your price range?
If the price isn't to much of an issue I like the prince of tone. The switch is handy as you get to select it in boost/od/distortion and it sounds pretty good in all three positions. And it stacks better than many other pedals I have used.
That said I do also for my medium gain like to run..... a hotone golden touch... Haha. With the switch on to fatten and gain it up and wound out, it sounds actually pretty good.
Pretty much any distortion that isn't an angry bee distortion can sound good on an old fender
I am about to start building a pedal from a kit that’s after the original 1989 Marshall guv’nor. Just worried it’s going to be super noisy since it’s a bit of a one trick pony. I’d like something similar to a clon but with maybe 1.5x more gain. Maybe I need a comp and an eq and a noise gateWhat kind of medium high gain are you looking for and what's your price range?
The hotone golden touch is one of those funny little mini pedals. I think I paid 50 or 60 for it. It has a little noise but its really not that badThank you, I have never heard of each of these pedals. The one I have right now for higher gain is a cheap amazon thing for metal and it’s just too much to try and dial it in at super low drive when stacking with a Klon
5150 pedal or amp head?I'd buy a 5150 or something. Can find em used for very reasonable...and consider changing amps if you want high-gain sounds that you can slam with your pedal.
I'd get the amp if you can find a good one...they're fantastic...haven't tried the pedal.5150 pedal or amp head?
I have a guv'nor and it is reasonably noisy but any higher gain pedal will have some noise. That and the bluesbreaker sure make a fair bit of noise.I am about to start building a pedal from a kit that’s after the original 1989 Marshall guv’nor. Just worried it’s going to be super noisy since it’s a bit of a one trick pony. I’d like something similar to a clon but with maybe 1.5x more gain. Maybe I need a comp and an eq and a noise gate
Boss SD-1 Super Overdrive pedal. Kinda like a Tube Screamer but with more variety and versatility.I have an original 1966 Princeton and want to run medium high gain distortion with my DIY overdrive I built. I also have a Klon clone, but I’d like to run something a bit hotter for the base distortion. Any thoughts? View attachment 1003370
Thank you, I will also use my other guitars with it, but want to dial the tele in first. I’m hopeful about the build. Excited to see how it soundsI have a guv'nor and it is reasonably noisy but any higher gain pedal will have some noise. That and the bluesbreaker sure make a fair bit of noise.
I personally don't mind a bit of noise as it let's me know that something is on.![]()
Are you going to do a build thread on the guv'nor build? I'd follow that for sureThank you, I will also use my other guitars with it, but want to dial the tele in first. I’m hopeful about the build. Excited to see how it sounds
Yeah I can do that for sure. This will be my second pedal build but I’m pretty confident. Here is where I ordered the kit from. Good prices but sadly lots of stuff is out of stock at the moment. Build your own cloneAre you going to do a build thread on the guv'nor build? I'd follow that for sure
Which forum should I post that build into?Are you going to do a build thread on the guv'nor build? I'd follow that for sure
The burnt fingers diy effects forum. Looking forward to itWhich forum should I post that build into?
Yeah there is a shortage for some of the components used that really puts a cramp on getting things madeYeah I can do that for sure. This will be my second pedal build but I’m pretty confident. Here is where I ordered the kit from. Good prices but sadly lots of stuff is out of stock at the moment. Build your own clone
Probably not what the OP is looking for, but I do a tc Tone Pilot (modded with some capacitors shoehorned into the gain control to tame the treble) or/and a T- Rex Fat Shuga boost/reverb. That and a 12" neo speaker and a ss rectifier are a size jump in output for my Silverface no-verb.I'm always interested in seeing what folks are using with their non-reverb Princetons. I'm running an MXR Timmy and am very happy with the way it sounds with the gain up to around noon - it browns it up nicely and doesn't feel like a pedal, it feels like it turns the amp into a 6g2. One big plus is that it has a substantial db boost which the non-reverb amps really need to hang on a bandstand. I bet it would stack well with another pedal to kick on for leads.
