I've read in a book called Understanding Wood Finishing by Bob Flexner, that you don't have to use sanding sealers, and I quote:
"Products sold as "sanding sealers" don't seal the wood any better than the first coat of any finish. Sanding sealers just make sanding easier."
While your quote from Bob Flexer may work on general wood working finishes those are generally not metalic solid color or guitar level finish qualities.
My buddy
@eallen is absolutely correct - except for the fact that Flexner is
totally wrong!
This is a long post - but covers several topics that apply to this and other projects:
FWIW I worked in a paint/lacquer (which are NOT the same thing) lab for part of my 40 year career in coatings, where incoming raw materials were tested; formulations developed/tested, every batch of coatings tested, field inspection/testing was done if there were issues of certification of compliance were needed and so on...
Primers and sanding sealers were tested for penetration into wood surfaces, stain resistance (prevention of tannic acid bleed into topcoats for wood coatings)...
And critical sanding sealer tests were not only for penetration & adhesion (of both clear - for extended stain penetration time allowing color depth control by the applicator - and opaque types), but covered different types for use with different types of lacquer, water-based paint coatings, oil-based enamels, epoxies, polyurethanes, and industrial/military coatings you'd never encounter in retail or commercial paint stores.
=> Sanding sealers contain primarily different sizes/shapes of calcium carbonate and other pigments (yes, pigments can be "clear" OR colored) that the paint chemist/formulator selects in very specific ratios in order to *partially* fill the grain of a wide variety of wood. Sanding sealers - which are often also formulated to lock out tannic acid, light sap and other discoloring materials found in different woods - need to work on both lightly open-grain woods such as pine and mahogany to open-grain woods such as most types of ash.
Comparatively smaller pigment grains penetrate the grain more deeply; larger ones sit higher; "comparatively" is a key word, as with tighter grained wood medium-size particles only partially penetrate or don't penetrate at all, large particles sit on the surface held on my the sealer's resin (lacquer, acrylic, vinyl, alkyd etc) and as you go through wood types with progressively more open grain, the larger sizes penetrate.
When you
sand the sanding sealer ( and you just need to sand lightly so the surface is smooth, assuming the stuff was applied properly in multiple light passes in crosshatched directions) the grain is partially "locked".
The clear types prevent stains & dyes from penetrating both quickly and deeply too fast for the average applicator to control (which is done by wiping areas that start to absorb and get darker or mottled and "pulling" the stain or dye out of those areas.).
Without clear sanding sealer, many stained or dyed wood surfaces look like an inconsistent, mottled mess that's difficult (sometimes impossible) to correct.
The pigmented types allow enough penetration of the color coats for good adhesion, yet prevent them from being sucked into the grain like a sponge.
If you DON'T use a sanding sealer...and especially if you apply full coverage coats...(because
properly-applied lacquer is self-leveling) you'll have a very thin coating on the hard grain, a soaking-in of material in the soft/open areas and almost always some level of solvent entrapment in the open grain.
Always use sanding sealer (or a lacquer-compatible "stain preventative primer/sealer" on wood that commonly bleeds through coatings when applying an opaque finish (if you don't know which ones do, look them up!) - even if you don't think you need one! I did all 6 coats in one day about 15-20 minutes apart.
That's DEFINITELY one of the problems.
In my opinion, Duplicolor's application instructions - even for their products - are wrong. They say "lacquer does not have a recoat window" and "you can reapply lacquer at any time". They use roughly the same solvents as other aerosol lacquers - and those solvents and other volatile contents MUST evaporate full from each coat before the next one is applied.
LACQUER DRIES ONLY BY EVAPORATION - THERE IS *NO* CURE TIME. THE SOLVENTS AND OTHER VOLATILE COMPONENTS MUST DRY BEFORE RECOATING OR THEY WILL BE TRAPPED AS THICKNESS BUILDS AND AS THE TOP SURFACE DRIES TO THE TOUCH.
Those solvents DON'T EVAPORATE "at any time" and will be trapped in the open-grain areas. The stuff may "feel" dry - but that's not how you test for dryness. Without inspection tools, you don't - which is why you apply LIGHT COATS an hour apart to be safe.
Another side note - Stewart MacDonald's "Guitar Finishing Step-by-Step" (written by Dan Erlewine) is another book that is is wrong - he repeatedly states that lacquer has a "cure time", which is incorrect unless it's a catalyzed lacquer that undergoes a chemical reaction. Conventional lacquers - even StewMac's Colortone - dries by EVAPORATION only. Also - that book ONLY applies to Colortone...and by coincidence, Deft...lacquers. "Four days is the minimum drying period before rubbing out" is wrong for conventional lacquer; most finishers I know buff the next day. And "The finish coat will cure after three to four days" and "After a week of curing..." are both absolutely incorrect - there IS NO CURE TIME, even for Colortone lacquers. Some need a longer DRY time for evaporation - but "cure time" for lacquers is one of the MOST common misconceptions in the DIY guitar finishing world.
Back to general lacquer usage - the ONLY time you coat "wet on wet" or even "wet on tacky" with lacquer is with the LAST clear coat, and only if you have enough experience to know EXACTLY how to time that coat so it's not too thick, won't run or cause orange peel, and can go right to the buffer after about an hour.
And that takes a LOT of practice time AND actual finishing.
I have applied quite a bit of Duplicolor lacquer when clients wanted their metallic lacquer colors (rather than special ordering expensive pints or quarts and adding to hazarous waste leftovers).
By the way - you are applying an acrylic/nitrocellulose blended lacquer. For those who have doubted this in the past - read Duplicolor's aerosol "acrylic lacquer" MSDS and look at the contents: one is "cellulose nitrate"!!
Yes, Duplicolor is a blend of acrylic and nitrocellulose resins - "acrylic" is NOT listed on the MSDS because it doesn't HAVE to be - it's not hazardous! Blends are common because 100% nitrocellulose lacquer dries to a very stiff film, and is far more subject to early cracking, checking and dings.
In my opinion and based on my experience with dozens of lacquer products, the application instructions are wrong for 99% of the lacquer products on the market and will likely result in solvent entrapment, lap marks, "alligatoring" and/or orange peel. NEVER use those instructions for another brand of lacquer, and I don't recommend it with Duplicolor.
Unless you apply VERY light, transparent coats of Duplicolor - the traditional light, non-flowing coat made up of three VERY light passes of any conventional lacquer - you will end up with higher mil thickness in the areas of overlap - ESPECIALLY if you did not spray in a crosshatch pattern, and worsened because softer grain areas have sucked primarily solvents into the wood due to the lack of a sanding sealer.
When applying clear coats you inevitably re-wet the surface (whether applying the next coat right or wrong), and in thicker areas some pigments like to "float" into the clear coats, as lacquer becomes simply ONE coat as each applied coat melts into the previous one. But you had inconsistent pigment reaction with the first couple of clear coats because of inconsistent mil thickness and insufficient drying of the color coats.
And if you applied full coverage coats instead of light coats, with coverage and flow starting at the third or fourth color coat you were applying it too thickly - i.e. like paint.
Lacquer ain't paint.
IMO you applied the color coats too thickly and did not allow enough dry time between coats. I recommend stripping it and applying a lacquer sanding sealer; then apply whatever lacquer you end up using in THIN coats made up of three almost "fog-like" passes (with full coverage and flow not starting until the third coat) - and at least an hour apart.
