After considerable research I am still confused about this. I have read so much about modifications to fit a favorite wire or inventory into the available slots (widening slots, filing barbs, scalloping tangs, filling with glue, etc). What I do know is:
Make sure the slots are deep enough
Too loose and you risk lifting and tone issues
Too tight and you risk back bow
Different fingerboard woods may need different dimensions due to hardness like ebony
Things with no clear strategy:
Glue (yes/no), which one. I think this one just needs preference after experience. I'll probably start with Titebond.
Ideally how wide should the slot be vs tang width be and how much wider with the barbs
Dead blow hammer vs press
True fret radius vs slightly smaller radius (except SS)
The thing I need to settle right now so I can order parts is the fret wire dimensions. I can order anything I want, I can make it a really proper fit with no compromises and then maybe even get away with no glue at all. I am looking at Jescar and Stew Mac wire.
Once I get my slots cleaned out and measured what tang width do I want? Lets say my slots are 0.023". Do I want a perfect match at 0.023" tang width without the barbs or a few thou narrower, say 0.020 - 0.022"? There must be a range here because Stew Mac calls for a 0.023" slot width even though their wire has different tang widths.
On a refret do you just consider the same width as the existing fret wire?
Then what barb thickness or range of barb thickness do I want. If its a depends thing and you modify as you try to seat some test frets then how much bigger than the tang width do I need to start with?
Lastly, any guidance on how to tell if the frets are seating with the right amount of pressure/friction fit? One guy I saw uses a torque wrench on a rotating arm and caul set up which answers the questions exactly but I don't have that set up, at least not yet.
Thanks,
George
Thanks,
George
