What's the difference between Schaller Strap Locks and Fender Schaller Designed Strap Locks?
  • Thread starter Digiplay
bsman
Madison
About tree-fiddy!
I think the main difference I've noticed is that the Schaller version have a ball-end on the strap part, whereas the Fender version (and it's been a few years, so I don't know if this is still accurate) have a sort of flattened end.
Schaller:
Fender:
scooteraz
Peoria, AZ
Are we talking about these Fender strap locks?
https://www.sweetwater.com/store/detail/0990690000--fender-strap-locks-and-buttons-set-chrome
Or these?
https://www.sweetwater.com/store/detail/0990818600--fender-infinity-strap-locks-chrome
And the current production Schallers?
https://www.sweetwater.com/store/detail/StrapLkSchC--schaller-s-locks-security-strap-locks-chrome
And here are the Ernie Ball Super Locks
https://www.sweetwater.com/store/detail/4600--ernie-ball-p04600-super-locks-set-nickel
So, the first set of Fenders appear to be the old style Schaller locks. The current production Schallers solve some issues the originals had (mostly with the guitar strap nut coming loose if you didn’t use Loctite blue).
The second set look like Fender re-branded Ernie Ball Super locks.
scooteraz
Peoria, AZ
Those Fender locks are the old Schaller. They rely on a hex nut to hold the strap onto the lock, and if you don’t use Loctite Blue (or the equivalent thread locker), over time that nut backs off, and the strap can come loose.
The new Schaller has a thumb wheel style nut, with a locking screw. You tighten down the nut, then the jamb screw, and you don’t need Loctite. The strap nut is also a larger diameter and thicker, so easier to finger tighten. I don’t think there is much difference otherwise. The new strap buttons fit over the old guitar bracket (the part that screws to the guitar).
scooteraz
Peoria, AZ
So........................................................
The "real" Schallers are better than the Fenders?
Depends. I have a ton of Loctite Blue, and several full sets of deep socket wrenches. So the original is fine. And appears to be about half the cost. OTOH, the newer one comes with the little Allen wrench so if you have no tools available to you, you can lock that strap into place.
Low cost vs. convenience. Once you have the strap on the buttons, the way they work is identical. Beauty is in the eye of the beholder.
BTW, they are all “real” Schallers. Fender just seems to have a supply of the design that was manufactured by Schaller and has been considered great for 30 years. Schaller seems to only be selling the current production.
Torren61
Humboldt County, CA
I sent Schaller a message asking where their strap locks were made and if they make Fender's strap locks. Then I saw a closeup pic of their strap locks and they say "Made In Germany". I hope to get a response on the Fender strap locks. I bought some Schaller-type strap locks and they were JUNK. Never again. I love Schaller strap locks. They're all I use.
AAT65
Edinburgh, Scotland
Interesting!
I have the old style Schallers on two of my guitars — one Fender-branded and the other Schaller-branded, but pretty much identical. On the first ones I had the nut did come loose and early surprised me — so I’ve since made a point of checking from time to time and I have used a socket to get them as tight as possible. Good to know that Schiller have recognised the weakness and improved the design.
Bella
PDX
Since I just went down this road a few weeks ago, I'll weigh in with what I know about the current Schaller lock system ("S-locks").
The button screws are now permanently mounted to the buttons, unlike the originals which were seperate buttons and screws. Some prefer the older design because you could sometimes get away with using your stock button screws (depending on your stock screw head and thread diameters).
The button screws on the current model are hex heads so you'll need an appropriate Allen wrench.
The thumbwheel on the current model replaces the hex nut on the originals (as noted earlier in this thread). You can thumb tighten them, but there's also a hole routed through the thumbwheel that you can fit a narrow Allen wrench or small screwdriver through to tighten the thumbwheel more securely. The thumbwheel also has a set screw (a very tiny flat-head).
The threaded shafts that attach to the strap are longer than the originals, which helps accommodate thicker strap ends.
When you order the S-locks, they only come with two buttons with mounted screws (like you'd assume). However you can choose between two additional button sets with different screw sizes to better match your stock button screw sizes. Unfortunately, I believe that you have to order those separately and in addition to the standard strap lock kit. They only offer the full kit with one default screw size. I don't recall the measurements of the standard set screws or the additional sizes they offer, but that info is available on the product page at the Schaller site.
I measured the stock screws on my LP Custom before ordering and checked the Schaller product specs. Fortunately, my stock screws matched the measurements of the screws in the standard Schaller kit, so I didn't have to order additional button-screws or resort to drilling or plugging the existing strap button holes.
The S-lock kit does not come with any tools, however the product page provides the info for the tool sizes you'll need for the button screws, thumbwheel mount route, and thumbwheel set-screw.
There's also a short video available on there that will better illustrate the above and give you the basics on installation and usage of the locks.
I usually use rubber washers for locks which work great on my Teles, but not as great on my LP, so I ended up doing a ton of research on strap lock systems before I decided on the Schallers.
Torren61
Humboldt County, CA
I email Schaller and they got back to overnight. Their strap locks are made in Germany and they don’t make Fender strap locks.
I love Schaller strap locks. They’re the only kind I use.
Guithartic
Jacksonville
Last year, I got a cheap set (about $3) of unbranded Schaller-looking ones from wish.com, and the little ball came off the post while they were on my 1999 American Standard Strat.
I had to use a hack saw to get it off, which was unnerving, because it was my first legit guitar I bought new in ‘99, and it was in mint condition.
bsman
Madison
I’ve actually moved away from strap locks and now exclusively use rubber washers (e.g. “Grolsch”). I got a hundred from the evil empire (aka Amazon) and am glad to not have to worry about loctite, small parts, and problems…
