richard1986
Hi all,
I've got an amp I made a few years ago which has a 350-0 primary so makes about 500v after a bridge rectifier.
At the time, I could only get 450v capacitors for the screen grid and preamp supplies, so if you turn the standby switch on too soon you risk blowing them up. I'm not happy with this, so I'm going to change it.
I can get 500v capacitors easy enough now, and I'd like to use some zener diodes to drop the voltage a bit more, for a margin of error and because I know mains voltage is often higher than it really should be around here, and I don't need the power. I know I could just use 600v caps, but they're 5 times the price.
If I put a string of zeners between the zero tap and ground, does that reduce the voltage the filter caps see before the output section conducts? I'll be aiming for about 475 I think.
Thanks,
Rich
Thanks,
Rich
