AlbertaGriff
And, I'm pretty sure, wattage rating being equal, ceramics break up earlier than alnico.
Is this true? I always thought it was the opposite.
If the band is doing their job, they drown out the hum!I actually don’t mind the humbuzz, at least up to a point. I’m a humbucker guy to the core, but I do have one P90 guitar for the sake of variety. If I turn a certain way, the humbuzz appears, but I figure that’s the price you pay for SCs. If it starts to annoy me a bit, I just go back to my beloved humbuckers.
I came up with that line because some insist on SCs and then want SCs with no hum. That always cracks me up.
Or just turn the volume pot to zero on the guitar.If the band is doing their job, they drown out the hum!
If it's too much between tunes, I step on my tuner.
Copper shielding tape seems to help a bit, but, in the final analysis, if you want that P90 tone, you have to accept some level of humbuzz. The rose and the thorns, as it were.Or just turn the volume pot to zero on the guitar.
There is, however, no way of getting around single coil hum. It is a reality. Noise gates can help if one uses single coils in higher gain situations, I suppose.
I'm more talking about the vintage guys.
Mainly the tweedss.
So many talk about how you NEED a 12AY7 in V1, then jumper the channels which, to my ears, ups the gain in a very similar way to running a 12AX7.
It seems that way to me.
I like ceramic speakers.
I have the same 330 in the attached vid. it comes from the factory with hum cancelling P 90s. I like the way they sound.....
the spec sheet lists them like this:Gibson used to call those P-100s, did they not?
P-100s were actually a stacked-coil pickup, two P-90 coils on top of each other in parallel with one reverse wound. Weedy unless you rewired them to be in series. The Memphis ES-330 in the vid has single-coil MHS P-90s which aren't individually hum cancelling, but the bridge pickup is reverse wound so when they're both on the effect is like a humbucker.
"MHS P-90 pickups with hum-canceling capabilities"
Neither pickup is a humbucker. The combination operates in a humbucking mode.
