headly21
Many discussions here, but I haven't found my particular situation addressed yet.
I bought an unfinished ash Tele body from a vendor at a guitar show who had stacks of unfinished Tele bodies. I'm providing this detail because I wouldn't know the dimensions of the string-through ferrule holes until now.
I've been finishing the body with lacquer over the last few months. The string-through ferrule holes were pre-drilled when I bought the body, and I recently bought me some standard Fender ferrules:
* 5/16" diameter
* 3/8" diameter lip
* ~0.302" tall
Well, dropping a ferrule in to one of these holes is like throwing a hot dog down a hallway; except the lip stops it from falling through. Insert innuendo of your choice here.
The diameter of the holes (with some lacquer that got inside) are right around 3/8" (0.375") and about 0.45" deep, which is deeper than the ferrules are tall.
So, my question is, should I be looking for a different size (larger) ferrule, or do I try to heat them up to get the lips flush with the body? If I get the lips to stick tight in the holes flush with the body, that's the only part that will be in contact with the wood. The rest of the ferrule would kinda be floating around inside the hole, so to speak.
Thanks for your help!
* 5/16" diameter
* 3/8" diameter lip
* ~0.302" tall
