X59 Supersonic jet with no boom
Discussion in 'Bad Dog Cafe' started by uriah1, Oct 18, 2021.
  1. uriah1
    Around
  2. Blister
    Blister Tele-Meister
    Upstate New York
    Whoa I wonder how long that’s really been around
    uriah1 likes this.
  3. stxrus
    stxrus Poster Extraordinaire
    St. Croix, USVI
    Very, very cool.
    I remember, as a kid, living in and around Air Force Bases hearing sonic booms fairly regularly.
    uriah1 likes this.
  4. Ricky D.
    Ricky D. Doctor of Teleocity
    Marion, VA
    Hush-a-boom!
    Dan German and uriah1 like this.
  5. unixfish
    unixfish Doctor of Teleocity Silver Supporter
    Northeast Ohio, USA
    Band name alert!
  6. unixfish
    Northeast Ohio, USA
    I would have loved to read a bit more about how the reduced the boom; I am assuming this is related to air velocity over body panel and low pressure / high pressure zones with gets into coefficient of drag.
    I have been wanting to post "OK, boomer!" but I have thus far resisted the urge. :D
  7. Larry F
    Iowa City, IA
    Lots of sonic booms when I was growing up in WA state. Is it true that pilots started breaking the sound barrier vertical rather than horizontally?
    In the mid sixties, one boom, however, was the real deal. A fighter jet in trouble was kept away from populus areas as the pilot steered into the hills outside of town. He chose not to eject.
    naneek, uriah1 and Timbresmith1 like this.
  8. Timbresmith1
    Timbresmith1 Tele-Afflicted
    Central TX
    I kinda miss hearing the dishes rattle when the sonic boom happened. I also miss the C-130’s flying low over the lake.
    uriah1 likes this.
  9. Dan German
    Dan German Doctor of Teleocity Silver Supporter
    Left of the Left Coast
    Definitely a thing I heard growing up in the St. Louis area. Probably shouldn’t have been doing it where it could be easily heard in residential areas, but as a kid, it was nothing but cool.
    uriah1 likes this.
  10. Buckocaster51
    Iowa USA
    Admin Post
    When I was a kid the boom made by the afterburner kicking in on Wis Air Guard F-102s flying out of Madison were often confused with sonic booms.
  11. Guitarzan
    Guitarzan Poster Extraordinaire
    Hotlanta, GA
    Yes, they experienced in dives the compressability that occurs on approach to the mach in WWII when the aircraft had enclosed cockpits and were the fastest they had ever been. They did not have good knowledge of it them, or that the speed of sound is variable depending on factors such as temperature, humidity, and pressure.
    naneek and uriah1 like this.
  12. boneyguy
    boneyguy Doctor of Teleocity
    victoria b.c. CANADA
    I heard the 'booms' a lot as a kid growing up in North Bay, Ontario, Canada...a small city that has an air force base....it was/is part of NORAD. It was a pretty common sound now that I think about it. I haven't heard a boom for many years now.
  13. rdjones
    rdjones Tele-Meister
    Music City, TN
    Nahtabot and uriah1 like this.
  14. uriah1
    Around
    Darpa does all the fun things.
    Didn't they invent the internet, per se.
    That Cal Webway likes this.
  15. KokoTele
    KokoTele Doctor of Teleocity Vendor Member
    albany, ny [not chicago]
    Not on purpose, and they usually died as a result. There are some reports of flights in WW2 from both the Allied and Axis sides where the plane was pretty clearly either in the transonic range (where flow over parts of the plane are starting to go supersonic) or supersonic.
    One of the major problems they had to solve to successfully fly supersonic was pitch control. When supersonic air hits a hinge line, it causes a shock wave. Behind that wave is low pressure, so a control surface there doesn't have enough airflow to be effective. This is why jet fighters move the entire tailplane instead of having elevators.
    naneek, Larry F and uriah1 like this.
  16. Guitarzan
    Hotlanta, GA
    Did you see any of the video of the boom at Oshkosh back in August?
  17. Guitarzan
    Hotlanta, GA
  18. Guitarzan
    Hotlanta, GA
  19. Killing Floor
    Killing Floor Poster Extraordinaire Silver Supporter
    Austin, TX
    Cool. I think they'll get there eventually. it won't be completely without a sonic boom at some level because the atmosphere is really, really important and stuff. But it could absolutely be minimized to very low level that you might not notice on the ground. Planes don't need flattened frontal shapes or areas to achieve lift and frankly anything can lift with enough thrust.
    I did a senior research project at AEDC where we surface heated the upper skin of airplanes (models) and the lift was improved with less thrust energy required for takeoff because you could control where the friction was applied. They have a massive compressor driven supersonic wind "tunnel". Point is there are a number of ways to reduce the shock wave. It is really exciting to see this kind of engineering. It's not about beating physics, it's about applying it.
    Come on over and sit a spell, let's talk about gas dynamics.
    KokoTele likes this.
  20. That Cal Webway
    That Cal Webway Friend of Leo's Silver Supporter
    Minot
    Marshall amps successfully performed sonic boom trials in 1972.
    aks Ritchie Blackmore
