Wrong Fuse?? Harmful??
Discussion in 'Amp Tech Center' started by Joe M, Oct 22, 2020.
  1. Joe M
    Joe M Super Moderator Staff Member
    Michigan
    Admin Post
    As most of us do, with way too much time on my hands, I find things that I probably never would normally...latest discovery, for whatever reason, I checked the fuse in one of my amps. Says it’s supposed to be 1.5 amps, slo-blo; the one in the amp is 1 amp, slo-blo. I know you should never use a higher value fuse, any problem with the lower value?
  2. Peegoo
    Peegoo Poster Extraordinaire
    Yonder
    No, but it means it may blow when it really should not.
    The danger is when a fuse with a higher amperage rating is used. Example: in the old days of glass fuses (before circuit breakers) were used in power panels for homes, it was sometimes a "quick fix" to place a penny behind a blown fuse when a spare fuse was unavailable. Many houses caught fire as a result.
    Slo-blo is necessary because amps can draw transient current far in excess of the normal operating current of a circuit. The 'slo' type requires an extended over-draw condition to blow. If the amp calls for a 1.5A slo fuse and you install a standard fast-acting fuse rated for 1.5A, chances are good it will blow in use.
  3. elpico
    elpico Tele-Afflicted
    Vancouver BC
    The smallest fuse you can get away with (without nuisance failures) is the safest fuse, regardless of what it says on the amp.
