bluesholyman
I found a Fender black face DRRI, mid-2000s I think (rubber switch covers) with a Celestion Gold speaker installed - the ask, mid $600s. Everything seems to check out fine, reverb works great (excessive really) tremolo works (from footswitch only - probably normal.) It currently has Groove Tubes in it, which is the only down side I see - the 6v6s are graded at "2" which I think is pretty cold - the amp has a lot of clean room - 6 is barely cracking the dirt if at all. You have to get on it. ( I feel like I have heard DRRI's that gallop a lot sooner on the volume dial.)
Tolex is in great shape, almost looks new but age is clear from oxidation on power tube cage - some light rust. I am guessing the amp was gigged in a flight case and saw some outside work or a few beers - but it does not look at all like a "gigged" amp.
the amp sounds good, but not magical or 3D'ish, as I have heard from some - it feels a bit reserved. I think this is the power tubes doing that. I have no respect for GT tubes but maybe its inherent bias on my part messing with my ears.
This seems like a really good deal, and I even have time to check it out and return (or have fixed) if there is an issue.
Would appreciate your thoughts.
