I have a beautiful spalted maple drop top. It is glued up to the body and all rough cut to shape. I have not worked with spalted maple before and I'm realizing just how fragile it is from a piece of the off cut. I'm likely use some polyester filler/sealer or epoxy like Solarez or zpoxy to do the grain fill on the back and any fill any little voids on the spalted top.
Anything else I should do to the spalted maple to stabilize it or will the sealer soak in enough and do the trick as well as just being glued to the back?
If I do anything to it, should I do it before routing to final shape and routing the pickups and neck pocket or do it at the end just before finish?
Thanks.
Thanks.
