Wiring S/H Tele with 5 way switch
Discussion in 'Tele Home Depot' started by Chicken Curry, Apr 11, 2021.
  1. Chicken Curry
    Chicken Curry Tele-Meister
    I'm new to wiring guitars, just purchased parts but pickups and control panel need to be put together.
    Any advice on wiring up a 5 way switch?
  2. peterg
    peterg Tele-Meister
    Toronto
    Chicken Curry and crazydave911 like this.
  3. jvin248
    jvin248 Doctor of Teleocity
    Lions & Tigers oh Mi !
    Is your humbucker two, three, or four wire?
    Easiest is treat the humbucker like a standard single coil neck pickup then follow the traditional diagram.
    Use a push/pull tone pot and split the humbucker to a single coil.
    Some like to install a fixed 470k resistor at the switch and a 500k volume pot so when switched to the bridge pickup the fixed resistor knocks down the volume pot effectiveness as a 250k for better single coil tone and use the straight 500k volume pot for the humbucker.
    Measure your pots with a multi-meter and see where they sit on the tolerance spec (it's 20% wide) as they can alter your tone just like selecting 250k/500k will do, bright or dark output even when the knobs are 'dimed'.
  4. Chicken Curry
    Interesting website, looking through it now, thanks. The only selector switch I have is a 5 way switch. Parts are expensive here in oz ($30 for a 3-way switch!) and I'm not buying new parts as I'm new to this so right now using what I got.
  5. Chicken Curry
    Two wires from both the humbucker and single coil bridge pickups. White wire and bare.
  6. erix
    erix Tele-Meister Silver Supporter
    MI
    Chicken Curry likes this.
  7. peterg
    peterg Tele-Meister
    Toronto
    This is a good option.
