Wiring question...
Discussion in 'Tele-Technical' started by Flying Teapot, Mar 12, 2020.
  1. Flying Teapot
    Flying Teapot TDPRI Member
    Derby, England.
    Hi,
    I’ve swapped my bridge to fit a Bigsby to my Mexican Tele. I can’t remember where the unattached connection on the photo came from when I took it apart and strangely I don’t seem to be able to find the answer online. Can anybody solve this one for me?
  2. scooteraz
    scooteraz Friend of Leo's
    Peoria, AZ
    Lug for the bridge plate ground? Looks like that to me.
    Chipss36 likes this.
  3. sleazy pot pie
    sleazy pot pie Tele-Afflicted Gold Supporter
    austin
    Do you mean the ring at the end of the wire?
    That is a ground. Put it between the bridge and the tubing on one of your pickup adjustment bolts.
    howardlo likes this.
  4. Flying Teapot
    Derby, England.
    Thanks, I did that but the bridge pickup still isn’t working. I think the problem may be the contact with the pickup selector switch.
  5. Si G X
    Si G X Tele-Afflicted
    England
    You have a problem somewhere else, that is 100% a ground wire. You don't really need it because the bridge is connected to ground through the pickup base plate and the screw going into it but it won't matter either way, it's not anything to do with the function of the pickup.
  6. Flying Teapot
    Derby, England.
    Yeah, I’m pretty sure there’s a problem with the contact on the pickup selector switch. Nothing has come loose so it can’t be contacting correctly although it looks as if it is.
  7. schmee
    Be careful the switch isn't grounding inside the body if it's shielded, did you change the switch? Or a bare ground wire isn't contacting the switch when you screw down the control plate. Try loosening the plate and let it hang, do things work then?
  8. tubejockey
    tubejockey Tele-Holic
    the bozone
    It is remarkably easy to break the pickup winding when taking it in and out. Measure the resistance at the solder joints of the pickup.
  9. tube.tone
    tube.tone Tele-Meister
    Northeast
    I had a 2006 American Standard and that lug was screwed into the control cavity, which was painted with conductive paint.
  10. Danb541
    Danb541 Friend of Leo's
    Raincaster, Oregon
  11. Danb541
    Raincaster, Oregon
    preactor and Si G X like this.
  12. Peegoo
    Peegoo Poster Extraordinaire
    Challenging Definitions of Sin
    DanB for the win!
    Si G X likes this.
  13. Si G X
    England
  14. schmee
    UGH, that's too bad. It happens. I repaired one once, depends on where it broke.
  15. tube.tone
    Northeast
  16. mkdaws32
    mkdaws32 Friend of Leo's Gold Supporter
    Moncton, NB Canada
    That looks fairly easy to fix, with good soldering technique. I had cheap a dual rail pickup where one coil broke about a millimetre from the bobbin. I took the tape off and tried to unwrap a bit of wire and ended up killing it. Not worth going further with a $10 pickup - went in the trash.
  17. Flying Teapot
    Derby, England.
    Thanks for the help everyone. Great spot by Dan on the copper wire, I’ll try that next!
