Wiring issues..please help
Discussion in 'Tele-Technical' started by Dietcokedream, Aug 1, 2020.
  1. Dietcokedream
    Dietcokedream TDPRI Member
    Salt Lake City, Utah
    I’m putting an old guitar back together and am having an issue with the wiring. I have all of the connections soldered up, test each pickup, no issues. When I put the pick guard into the guitar something is killing the signal. Any ideas? I’m sure it’s something simple.
    Thanks for the help!
    rangercaster likes this.
  2. Martinp
    Martinp Tele-Afflicted
    Westbury, N.Y.
    is the control cavity shielded?, one of the bits could be shorting to it?
    rangercaster and Peegoo like this.
  3. Dietcokedream
    It is not shielded
  4. rangercaster
    Knoxville TN for now
    Just sell it and buy one that works...
  5. Collin D Plonker
    Collin D Plonker Tele-Meister
    Delaware
    What kind of guitar? What kind of wire?
  6. dogmeat
    dogmeat Tele-Afflicted
    Alaska
    the guard is pushing one of the signal wires to ground. easier to do when the cavity is shielded but that is not a requirement
    Collin D Plonker likes this.
  7. titchy
    titchy TDPRI Member
    Allesley
    You've got a positive wire touching the ground. What guitar is it ?
  8. Collin D Plonker
    Delaware
    Or a ground touching a positive. Like a ton of Gibson-type shielded pickup wire stuffed into the control cavity.
  9. Dietcokedream
    It’s a Stinger ssx. An old Martin made Strat copy. It was my wife’s first guitar as a teenager. She won’t let it go. I found the problem and it’s all functioning just right! Thanks for the tips.
  10. schmee
    Often it's the switch hitting a wire or the cavity shield.
    Otherwise it's wires grounding on a pot or etc. Especially if metal shielded wires!
