Lostininverness
Hi All,
I've finished wiring up a jazzmaster type build with dual humbuckers, 3 way all parts toggle switch and 2 concentric vol/tone pots. I've got a humming in various pick up positions. The humming drops away if I touch the pickups, pots shielding or bridge.
I used 4 core shielded wire from the switch to the pots, shielding paint in the cavity and tape on the back of the pickguard.
Bridge and control cavity are earthed to the bridge pot, along with the bridge pickup. The switch and jack are earthed to the neck pot. Both pots are eathed together via the middle lug of the tone part of the pot. (using vintage wiring)
I've also "jumpered" the outside lug of the vol part of the concentric pot to the middle lug of the tone part of the pot.
So used this plan for the "joining" tone and volume pots.
guitarelectronics.com
All advice is appreciated - so frustrating! I want to get this sorted before I put the neck on and string it up.
Cheers
Grant
Humbuckers/3-Way Lever Switch/2 Volumes/2 Tones/Vintage
Basic guitar wiring diagram with 2 humbuckers, 3-way lever switch, two volumes and two tone controls. <strong>Click diagram image to open/view full size version.</strong> </strong> Ready to get started? Don't forget the <a...
Cheers
Grant
