Wiring Help Please!
Discussion in 'Tele-Technical' started by spayne99, Jan 17, 2021.
  1. spayne99
    spayne99 Tele-Holic
    NJ
    I've got a used Tele here that I'm rehabbing a bit. Its a 60th Anniversary, the one with the blonde thin skin lacquer. When I opened it up I discovered it has a Seymour Duncan Vintage Stack Neck pickup STK-T1N, and a BG-1400 bridge pickup.
    I might go with more traditional pickups but for now I'm gonna give these a try. I ordered a Mojo Tone standard (3 way) solderless harness and I want to wire the pickups to it.
    Right now it still has the existing wiring and this is what I see...
    Neck pickup
    - in the body cavity there's red/white vinyl wires combined together and taped
    - white cloth wire to the switch
    - black cloth wire to the volume pot
    Bridge pickup
    - black cloth wire to the body ground
    - red and white vinyl wires combined together and taped
    - green vinyl wire to volume
    - black vinyl wire to switch
    The existing pots are 500k and there's a 33 cap. The Mojo Tone harness has 250k pots and a 47 cap. Maybe not ideal for the existing pickups but fine for now since I may switch to traditional pickups later.
    The instructions show the pickup wiring to the Mojo Tone 6 hole harness connection point as...
    - 1 Neck pickup hot
    - G neck pickup ground
    - 2 bridge pickup hot
    - G bridge pickup ground
    - 3 input jack hot
    - G input jack ground
    And the bridge ground connects to the volume pot via a screw
    I want to make sure I get this right. Based on the wires coming from the pickuos I outlined above can you confirm where they go on the Mojo Tone connection point?
  2. Boreas
    Boreas Friend of Leo's Silver Supporter
    Adirondack Coast, NY
    I am trying to figure out where the CLOTH pup wires originate. The originals pup wires are all vinyl, correct? You should track down the cloth wires to see where they originate at the pup. Then either replace them with the proper color or just MARK them somehow so you know to what color they correspond if they are not the same color. A wrap or two of colored vinyl tape will work.
    Then, the S/D site should be able to help with what the original pup wires are - hot, ground, etc.
  3. spayne99
    spayne99 Tele-Holic
    NJ
    I took the pick guard and bridge off to get a closer look. Turns out that whoever did the pickup install used the cloth wiring as extensions to the green and black wires on the neck pickup. All good now... actually since I had it all apart I just decided to yank the pickups out and ordered some Original Vintage pups LOL.
    Boreas likes this.
  4. Boreas
    I am using a set of those and like them a lot! Enjoy!
