Wiring help for Seymour Duncan Quarter Pound in G&L ASAT
  • Thread starter Travisb1989
Travisb1989
Riverside, CA
Hello All,
I have a G&L Asat Classic S Alnico and I am trying to put a Seymour Duncan Quarter Pound Tapped in the Bridge. However I am unsure how to wire it. I installed a push/pull tone knob, but I don’t know how to wire it so that I can activate the tapped(lower output) when I pull up on the tone knob. Any help would be most appreciated. Attached is my current schematic. I want it so when I pull up on the tone knob the bridge pickup is tapped and down is full power.
Thank you for your time,
Travis
Deaf Eddie
Beautiful Idyllwild, CA
This should do it:
Note that with Seymore Duncan pickups, TYPICALLY the black is hot, the green is ground, and the red and white are the series pair.
The tone p/p grounds the series pair when pulled, shunting ONE of the coils.
IF you find that the S-D bridge plays out of phase with the G&L pickups, simply reverse the S-D black and green. No need to rewire the p/p, it will simply leave the other coil active.
