Wiring gurus needed
Discussion in 'Tele Home Depot' started by mefgames, Dec 30, 2011.
  1. mefgames
    mefgames Friend of Leo's Platinum Supporter
    North Bay, Ca
    I am building a Baritone guitar for my son. He is very particular about how he would like the controls to function. I have no problem with his requests except that I am no wiring expert. I am not even sure what he's asking is possible without a few mods so it works properly.
    So here's the layout
    2 Humbuckers
    a Les Paul-esque switch in the upper bout to switch between Bridge/Both/Neck
    Now comes the interesting part.
    2 mini toggles that function as follows
    rear mini toggle
    up=bridge rear single coil
    middle=bridge humbucker
    down=bridge front single coil
    front mini toggle
    up=neck rear single coil
    middle=neck humbucker
    down=neck front single coil
    This seems to me that another switch would be required to actually switch between these 2 different circuits, and there is some double coverage. I have searched high and low on all the pickup and wiring sites for some insight, to no avail.
    So, if someone here has some constructive solutions, I would like to hear them, better yet see them diagramed out.
    Almost forgot 1 vol and 1 tone
    Thanks, Mike
  2. clsatt
    clsatt Tele-Afflicted
    virginia
  3. Pauleo
    Pauleo Tele-Meister
    Baltimore
    For this you will need two DPDT (Double pole double throw) toggles in ON- OFF- ON configuration. You can get these from any guitar parts store or Mouser.com
    I've done this wiring for a few of my guitars.
    Now this really depends on the pickups you are going to use as each has their own color coding. For the sake of simplicity let's just use Seymour Duncan.
    The black wire (hot wire) will go to the top left lug of the dpdt. You will run that connection to the pickup selector.
    The white and red wires which, are wired together, go to the middle left lug of the dpdt switch.
    The green and bare wires go to the bottom left lug of the dpdt. You will run this connection to ground.
    Repeat for the neck pickup, you will get either coil with series humbucker in the middle.
  4. Pauleo
    Pauleo Tele-Meister
    Baltimore
  5. megafiddle
    megafiddle Former Member
    VA
    Each switch controls one pickup: selecting between coil 1, coil 2, or humbucking (both coils).
    If that's what he does want, I believe it would be easy. You would need SPDT switches,
    with ON-OFF-ON positions.
    (corrected - misread post)
    Switches are as in diagram above. You can use SPDT or DPDT. Notice one half of switch (one pole)
    isn't used.
  6. Shepherd
    Shepherd Friend of Leo's
    Maple Ridge, Canada
    Sounds like he needs one of these
  7. megafiddle
    VA
  8. braderrick
    braderrick Tele-Afflicted
    Kentucky
    If you're using humbuckers ya just can't beat the Seymour Duncan Triple Shot mounting rings. I have them on one of my Les Pauls and they are available in either cream or black. They have two tiny switches on each ring that will do 3 combos with each pickup. You have the humbucker in series, the humbucker in parallel, and the front coil or the back coil. It's pretty nice too because you just wire your pickups to the rings and then the leads that come of the rings are simple 2 conductor leads keeping your control area neat and simple.
