Wiring diagram - twin HB's two vol two tones - 4 x push pull - series parallel - coil dump
old_picker
Melbourne Australia
Chasing a wiring diagram that will operate mods from 4 push pull pots:
Neck vol up = neck coils in parallel
Neck tone up = neck coil dump - slugs
Bridge vol up = bridge coils in parallel
Bridge tone up = bridge coil dump - slugs
The Jimmy page mod seems to be common but cant find one initially that achieves the above.
Thanks for any and all suggestions
old_picker
Melbourne Australia
Personally this is a mod I wouldnt be bother with. I would possibly use the series parallel but unlikely on a working guitar.
It's a customer request and after I get the wiring diagram sorted he'll probably nah too expensive.
Anyhow apart from the foregoing lets see if we can find a solution.
Would it be feasible to set up the series parallel push pull and route the slug coil to it via another push pull?
The slug hot wired into one of the middle poles of the switch and then from the opposite pole back to the series parallel switch.
Wire the up position poles to earth
jumper the down position poles.
switch in down position no effect on connection to series paralleled switch
switch in up position slug coil is earthed and out of circuit
remembering this mod is operating on each pickups individually -
jimmy page series parallel switching with both pickups in circuit not required.
eg bridge pickup has capability to have coils either in series, in parallel or screw coil active only -
achieved with ppull tone for coil dump and ppull volume for series parallel
I'll interrupt Deaf Eddie if we get nowhere here
